查看: 1621|回复: 0
[NI软件产品] NI RFmx CDMA2000 2024 Q1 Full/Runtime Win11 64bitENG RFmxCDMA2K完整版运行版24.0.0下载
    昨天 17:07
  • 签到天数: 3771 天
    连续签到: 22 天
     楼主| 发表于 2024-3-7 14:51:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2024/1/22
    包含的版本:2024 Q1完整版/运行版,版本号24.0.0
    64位完整版校验和:
    文件大小: 1043318784 字节 (994.99 MB)
    修改日期: 2024-01-23 09:59
    MD5: 6d3515f981381069cba7fd345e08809c
    SHA1: 268e511664cea09d0522b182aad571f5a416da17
    SHA256: 156ca6cf8d4f27539a9ea64adf788ba883da0acdf87647f383ddffd96fad2b2d
    CRC32: 1e81d73d
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K2024Q1.txt (549 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 927219712 字节 (884.27 MB)
    MD5: 3aa94072778df7c05db1ba959b1642e0
    SHA1: ac4384d7436e5f1f3bc7893b364ee59cf06a9bee
    SHA256: 559328a7c9ad4ed7fd7cad02301a4b7267e271d3f891c903167b4fee5daebea1
    CRC32: c1b7069b
    RFmx CDMA2K2024Q1RTE.txt (571 Bytes, 下载次数: 0, 售价: 5 圆)
    2024Q1版未更新自述文件,参考2023Q3版本
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Required Software
    Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2026-1-14 07:30
