查看: 1310|回复: 0
[LV工具模块] LabVIEW 2024 Q1 Model Interface Toolkit Win11 64bitEng LabVIEW2024Q1模型接口工具包MIT24.1.0
    15 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 2024-2-29 09:43:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW模型接口工具包可帮助您在开发控制系统时集成模型集成。
    LabVIEW模型接口工具包是使用VeriStand模型框架的附加软件。借助该附加软件,您可以将各种软件环境中的仿真模型和控制算法集成到LabVIEW和LabVIEW Real-Time模块中。您可以从LabVIEW控制设计和仿真模块以及第三方建模环境(例如The MathWorks,Inc. Simulink软件和C/C ++)导入控制算法和系统模型。您还可以组合来自多个仿真环境的模型,并同时运行多个模型。Simulink是MathWorks公司的注册商标。
    MIT工具包从2019版开始,2019~2020为32位版本,2021后为64位版本。
    LabVIEW 2024 Q1 Model Interface Toolkit模型接口工具包MIT24.1.0
    发布日期:2024/1/22
    包含的版本:2024Q1完整版,版本号24.1.0
    文件大小: 1302435840 字节 (1.21 GB)
    修改日期: 2024-01-23 09:49
    MD5: 72f121f2cb0d9389c0655a3c62c46d7a
    SHA1: 15f119b0b0f2207ea642360b3ebdf5072741ba1f
    SHA256: 4edf246294e5ac00351f215590c42b2627ef931125b4e56ae513041c3d44eb3c
    CRC32: a1476553
    百度网盘下载和NI官方下载地址:
    请注册登录视觉论坛会员,购买附件查看
    MIT2024Q1.txt (624 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q1版未更新自述文件,参考2021版
    LabVIEW 2021 Model Interface Toolkit Readme
    February 2022
    This file contains installation instructions and compatibility information for the LabVIEW Model Interface Toolkit.
    • LabVIEW Model Interface Toolkit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Accessing the Software and Help
    Use the LabVIEW Model Interface Toolkit to connect simulation models from a variety of simulation environments and programming languages to real-world I/O.
    The LabVIEW Model Interface Toolkit requires the LabVIEW 2021 Full or Professional Development System (64-bit) and any system requirements for LabVIEW 2021. Refer to the LabVIEW Readme for additional system requirements and supported operating systems.
    To integrate and run your existing compiled models, you only need to install the Model Interface Toolkit. To perform other tasks with models, there are additional software requirements:
    Task
    Software Requirements
    Develop a model using MathWorks Simulink® software.Install the following software as a licensed user on the host computer:
    • MathWorks MATLAB® software (64-bit).
    • MathWorks Simulink.
    Compile a model developed using MathWorks Simulink.Install the following software as a licensed user on the host computer:
    • MathWorks Real-Time Workshop® (Simulink Coder®).
    • VeriStand Model Framework. Install VeriStand Model Framework as an add-on in NI Package Manager. Refer to the NI website for a list of tested and supported compilers.
    Compile a LabVIEW VI into a .lvmodel or .lvmodelso file.Install VeriStand Model Generation Support for LabVIEW as a VeriStand add-on in NI Package Manager.
    If you use other modeling environments, contact your vendor about requirements for developing and converting the model into a compiled model.
    The LabVIEW Model Interface Toolkit supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 10 64-bit version 21H11
    • NI Linux Real-Time (Intel x64-based)2 3
    3 RT targets require a driver version that supports LabVIEW Real-Time Module (64-bit).
    The LabVIEW Model Interface Toolkit supports the following application software versions, including service packs.
    Versions Supported by Model Interface Toolkit
    LabVIEW Full or Professional Development System (64-bit)2021 SP1
    Download the LabVIEW Model Interface Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    The VeriStand Model Framework contains changes to the files you use to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled with previous versions of the Model Framework, choose from the following options for continuing to use the models in LabVIEW Model Interface Toolkit:
    • If you do not need to update your model or deploy it to Intel x64-based targets that run NI Linux Real-Time, you can continue to use the model as-is.
    • If you need to update functionality of your model that does not require the changes in the latest version of the Model Framework, you can recompile the model against the deprecated Model Framework files. These files are installed at \VeriStand\version\ModelInterface\custom\src\obsolete. However, you cannot deploy the recompiled model to Intel x64-based targets that run NI Linux Real-Time.
    • To use the new features in the latest version of the Model Framework, or if you need to deploy the model to Intel x64-based targets that run NI Linux Real-Time, update and recompile the models using the 2021 version of the Model Framework. Update your models according to the following differences between new files in the Model Framework and the deprecated files they replace:
      • ni_modelframework.h contains the following differences from NIVERISTAND_API.h:
        • Implements fixed-width data types from the C99 standard, such as replacing int with int32_t where applicable.
        • Replaces use of the long data type with int32_t or uint32_t where applicable to achieve cross-platform compatibility.
      • ni_modelframework.c contains the following differences from codegen.c:
        • This file is installed on disk at \src\ni_modelframework.c rather than in the directory.
        • USER_TakeOneStep() now returns an int32_t value rather than void. If the function completes successfully, it returns NI_OK. If an error occurs, this function returns NI_ERROR.
        • The USER_ModelName global variable is a const char and replaces the ModelName variable.
        • The USER_Builder global variable is a const char and replaces the build variable.
        • The USER_BaseRate global variable is a const char and replaces the baserate variable.
    To access the Model Interface Toolkit VIs, select View»Functions Palette from the block diagram in LabVIEW and navigate to the Control Design & Simulation»Model Interface palette. You also can right-click any blank space on the block diagram to display the Functions palette.
    Refer to the Toolkits»Model Interface Toolkit book on the Contents tab of the LabVIEW Help for more information about the Model Interface Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Model Interface Toolkit are located in the labview\examples\Control and Simulation\Model Interface directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The example models included with the Model Framework are located at \VeriStand\version\ModelInterface\custom\examples.
    LabVIEW Model Interface Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2013–2022 National Instruments Corporation. All rights reserved.
    375381F-01
    GMT+8, 2026-4-1 15:56
