查看: 1094|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite 2024 Q1 Win11 64bitEng 嵌入式控制和监控软件套件2024Q1英文版ECMSS24.0.0-64位
    昨天 17:07
  • 签到天数: 3771 天
    连续签到: 22 天
     楼主| 发表于 2024-2-28 10:59:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    套件包含:
    LabVIEW专业版
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW MathScript模块
    LabVIEW高级信号处理工具包
    LabVIEW数字滤波器设计工具包
    视觉采集软件
    视觉开发模块
    LabWindows/CVI执行评测工具包
    LabWindows/CVI Real-Time模块
    LabWindows/CVI SQL工具包
    LabWindows/CVI完整版
    Measurement Studio企业版
    发布日期:2024/1/22
    包含的版本:2024 Q1专业版,版本号24.0.0
    语言:英文English
    文件大小: 38277165056 字节 (35.65 GB)
    修改日期: 2024-01-23 09:45
    MD5: 34af092afe9f542f8514440487123195
    SHA1: 87915d5100c3c69dd2c12ad46fac3f6e8498338a
    SHA256: fd068c4eaf3de4df46e9bd34cdc54aa5507ec65731b49be41e35a8e32c1abf76
    CRC32: 894ca8c4
    ECMSS2024Q1x64Eng.txt (686 Bytes, 下载次数: 0, 售价: 40 圆)
    2024Q1版未更新自述说明,参考2023Q1版
    Embedded Control and Monitoring Software Suite 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for Embedded Control and Monitoring Software Suite 2023 Q1.
    • Embedded Control and Monitoring Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Embedded Control and Monitoring Software Suite
    Embedded Control and Monitoring Software Suite 2023 Q1 supports the following operating systems:
    The following products are included in the Embedded Control and Monitoring Software Suite installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    Add-ons
    Version
    Bitness
    FPGA Interface C API202032-bit and 64-bit
    JKI VI Package Manager2023 Q132-bit and 64-bit
    Vision Development Module2023 Q132-bit and 64-bit
    Drivers
    Version
    Bitness
    NI-Industrial Communications for EtherNet/IP2022 Q332-bit and 64-bit
    Note: Some drivers included with previous versions of Embedded Control and Monitoring Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions.
    If you are using the Embedded Control and Monitoring Software Suite .NET Class Library, .NET Framework 4.0 (minimum) is required. The Embedded Control and Monitoring Software Suite 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Embedded Control and Monitoring Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Embedded Control and Monitoring Software Suite. For more information on Embedded Control and Monitoring Software Suite activation, refer to Activating a Product.
    Embedded Control and Monitoring Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-14 07:32
