TA的每日心情 | 无聊 16 分钟前 |
签到天数: 3772 天 连续签到: 23 天 [LV.Master]2000FPS
楼主 |
发表于 2024-2-22 08:30:29
NI Astronics Ballard Avionics Driver 2024 Q1 Win11 32/64bitEng PXI航空电子通信总线模块仪器驱动程序24.0.0
Astronics Ballard Avionics Driver用于支持PXI航空电子通信总线模块。
Astronics Ballard Avionics Driver是LabVIEW的仪器驱动,其支持MIL-STD-1553和ARINC 429 PXI Avionics接口模块。该驱动程序还包含BTI XML编辑器,其可用于创建和编辑硬件配置文件。此外,Astronics Ballard Avionics Driver还包含示例VI,可帮助您入门。
发布日期:2024/4/22
包含的版本:2024 Q1完整版,版本号24.0.0
语言:英文English
文件大小: 1024688128 字节 (977.22 MB)
修改日期: 2024-01-23 09:46
MD5: a7260e8c2abf9949f540758f4b082ae8
SHA1: 867fcb1331603c343d8761564e94f9c0479ffe5e
SHA256: bd88565efb77861cbdc470babdf79aaf330595e836e5be20d408619b4166aada
CRC32: cae5eec8
请注册登录机器视觉论坛用户,购买附件查看下载地址
Astronics Ballard Avionics Driver 2024 Q1.txt
(578 Bytes, 下载次数: 0, 售价: 10 圆)
无自述文件。参考之前旧版:
Astronics Ballard Technology 1553 Instrument Driver Readme
1. Overview
Instrument Driver Technology: LabVIEW Plug and Play (project-style)
Manufacturer: Astronics Ballard Technology
Supported Languages: LabVIEW 2010 - LabVIEW 2021
Supported Operating Systems: Windows XP and above (32-bit and 64-bit), Pharlap ETS: LabVIEW RT 2013 and above, NI Linux RT: LabVIEW RT 2020 and above
NOTE: Pharlap ETS moved to legacy support with driver version 1.3.1 and LabVIEW RT 2020 and will only receive critical updates.
Supported Platforms: PXI, PXIe
Supported Models: LV-222-510-000, LV-222-511-000, LV-222-511-511, LV-222-550-000, LV-222-555-000, LV-222-555-555, LV-222-511-442, LV-222-555-442
Model Tested: LV-222-555-442
Interface: MIL-STD-1553
Firmware Revision Tested: G0
Certified: Yes
NI Supported: Yes
Source Code Available: No
Driver Revision: 1.3.2.2
Original Release Date: 05/20/2016
Current Revision Date: 09/30/2021
2. Required Software
Some software components need to be installed before using this instrument driver. The minimum versions of these components are listed below, and can be downloaded from the Download Site.
LabVIEW 2010 (for Windows)
LabVIEW 2013 SP1 (for LabVIEW RT Host running Pharlap ETS)
LabVIEW Real-Time 13.0.1 (for LabVIEW RT Remote System running Pharlap ETS)
NI-VISA 5.4.0 (for LabVIEW RT Remote System running Pharlap ETS)
LabVIEW Real-Time 20.0 (for LabVIEW RT Remote System running NI Linux RT)
Refer to the LabVIEW Help for more information about software requirements. You access the LabVIEW Help by selecting Help»Search the LabVIEW Help.
3. Known Issues
To report issues about this instrument driver, please send submit a support request here.
4. Getting Started
To install the Instrument Driver, execute the installer package file - "Astronics-Ballard-LabVIEW32-1.x.x.x.msi" for 32-bit systems or "Astronics-Ballard-LabVIEW64-1.x.x.x.msi" for 64-bit systems After installation, restart the host system.
The Instrument Driver may then be deployed to LabVIEW RT targets within the NI MAX tool. Select the target system then "Software." Then click the "Add/Remove Software" button.
- Pharlap ETS targets: Select the "Astronics Ballard Technology Driver Support" package from the software list
- NI Linux RT targets: Select the "astronics-ballard-labview" package from the third-party feed
Example VIs demonstrating the use of the driver can be launched from the start menu location:
Start | All Programs | Astronics Ballard Technology | LabVIEW Instrument Driver | LabVIEW XXXX Examples
The following documentation is provided:
- Library Documentation: Provides information about how to use the VIs of the instrument driver
- BTIXMLEdit Help: A guide for using the graphical configuration editor software
- Schema Help: Provides a definition of the input configuration files (XML) used by the instrument driver. These files can be viewed, edited, and modified in a text editor or any other XML editor as well as the graphical configuration editor software (BTIXMLEdit).
Astronics Ballard Technology 429 Instrument Driver Readme
1. Overview
Supported Models: LV-222-441-000, LV-222-442-000, LV-222-442-442, LV-222-458-458, LV-222-458-000, LV-222-511-442, LV-222-555-442
Model Tested: LV-222-555-442, LV-222-458-000
Interface: ARINC-429
Firmware Revision Tested: F0 (Std ARINC 429), F0 (Adv ARINC 429)
Certified: Yes
NI Supported: Yes
3. Known Issues
4. Getting Started
Astronics Ballard Technology Card Instrument Driver Readme
1. Overview
Supported Models: LV-222-441-000, LV-222-442-000, LV-222-442-442, LV-222-458-458, LV-222-458-000, LV-222-510-000, LV-222-511-000, LV-222-511-511, LV-222-550-000, LV-222-555-000, LV-222-555-555, LV-222-511-442, LV-222-555-442
Interfaces: ARINC 429, MIL-STD-1553
Firmware Revisions Tested: F0 (Std ARINC 429), F0 (Adv ARINC 429), G0 (MIL-STD-1553)
Certified: Yes
NI Supported: Yes
3. Known Issues
4. Getting Started
- Schema Help: Provides a definition of the input configuration files (XML) used by the instrument driver. These files can be viewed, edited, and modified in a text editor or any other XML editor as well as the graphical configuration editor software (BTIXMLEdit). |
