查看: 1248|回复: 0
[NI驱动程序] NI-SWITCH 2023 Q4 Win11 32/64bitEng/Jpn NI开关产品驱动程序23.8下载
    昨天 17:07
  • 签到天数: 3771 天
    连续签到: 22 天
     楼主| 发表于 2023-12-10 16:16:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    NI-SWITCH 2023 Q4
    发布日期:2023/10/11
    包含的版本:2023 Q4完整版,版本号23.8.0
    语言:英语,日语
    文件大小: 2643191808 字节 (2.46 GB)
    修改日期: 2023-10-12 09:48
    MD5: 7061faafdc8c3718a6b50f6f9b809d83
    SHA1: 7da32caf3b7305dc37185d4023f8baac5234d7c2
    SHA256: 9b1a39ac46974c5ecfcea0048612f667e432f057d5bd3808f0073866d57ad46c
    CRC32: 84790414
    Switch 2023 Q4.txt (522 Bytes, 下载次数: 0, 售价: 10 圆)
    2023Q4版未更新自述文件,请参考2023Q3版。
    NI-SWITCH 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-SWITCH 2023 Q3.
    • NI-SWITCH Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-SWITCH Documentation: Detailed documentation about how to use your product
    Include this section if your product supports Phar Lap ETS. NI no longer supports Phar Lap ETS Real-Time Operating System
    NI-SWITCH 2023 Q3 has the following requirements:
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    NI-SWITCH 2023 Q3 supports the following operating systems:
    • NI Linux® Real-Time
    NI-SWITCH 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-SWITCH 2023 Q3
    LabVIEW2020 and later
    LabVIEW Real-Time Module 32-bit2020 and later
    LabVIEW Real-Time Module 64-bit2021 and later
    LabWindows™/CVI™ Real-Time Module2019 and later
    If you are using the NI-SWITCH .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-SWITCH 2023 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Python Support
    For more information on installing and using the NI-SWITCH Python API, refer to the niswitch module.
    Download the NI-SWITCH installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "NI-SWITCH Support for LabVIEW" package supports applications using NI-SWITCH ​with LabVIEW 2022 or later. When installing NI-SWITCH, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Software Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version.
    Refer to the NI-SWITCH documentation, accessible from Start»National Instruments»NI-SWITCH»NI-SWITCH Documentation, for information about the NI-SWITCH.
    You can access all the installed NI-SWITCH examples at Start»National Instruments»NI-SWITCH»NI-SWITCH Examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SWITCH are located in the labview\examples\instr\niSwitch directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all NI-SWITCH examples.
    NI-SWITCH no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI No Longer Supports Phar Lap ETS Real-Time Operating SystemInclude this section if your product supports Phar Lap ETS.
    GMT+8, 2026-1-14 07:17
