查看: 1012|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q4 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.8
    昨天 17:07
  • 签到天数: 3771 天
    连续签到: 22 天
     楼主| 发表于 2023-12-8 09:01:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q4
    发布日期:2023/10/11
    包含的版本:2023 Q4完整版,版本号23.8.0
    文件大小: 5046984704 字节 (4.70 GB)
    修改日期: 2023-10-12 09:46
    MD5: b323691c2d7053e08a062e1b0c0cd354
    SHA1: 3bad216fb3753a5ea10dbe23674d34fd81cc2869
    SHA256: 22a70630f51d263fe23b3fd353bdb66698f7773ff8db4af655166dc70461355a
    CRC32: c89a6c3e
    RFSG 2023 Q4.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    2023Q4版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-1-14 07:19
