查看: 922|回复: 0
[NI软件产品] NI RFmx for Bluetooth Test 2023 Q4 Win11 64bitEng RFmx蓝牙测试NIRFmxBluetooth23.8
    昨天 17:07
  • 签到天数: 3771 天
    连续签到: 22 天
     楼主| 发表于 2023-12-6 09:08:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx for Bluetooth Test为不同的蓝牙技术应用提供信号生成和分析功能。
    RFmx for Bluetooth Test是一款测量专用软件,旨在扩展NI RF仪器生成和分析常规蓝牙和低功率(LE)蓝牙信号的能力。该软件可以帮助您调制精度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助RFmx,您可通过交互式软件前面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的、未锁定的波形,并并通过性能优化的API加快自动测试。此外,您可以使用RFmx for Bluetooth Test,通过内置的直接测试模式(DTM)命令来控制被测设备(DUT)。Bluetooth 为Bluetooth SIG公司的注册商标。
    发布日期:2023/10/11
    包含的版本:2023 Q4完整版/运行版,版本号23.8.0
    语言:英文English
    64位完整版校验和:
    文件大小: 1395826688 字节 (1.30 GB)
    修改日期: 2023-10-12 09:44
    MD5: 22535fb74f31634c51cc1627fcefe292
    SHA1: aa6833f263e58b29abd9cb0198108e2d3c95ea31
    SHA256: 30a34c3b1270bb12e87a698115a02af8ce8d1712d568cd2fb16b8ec29565a7a7
    CRC32: 134099be
    RFmx for Bluetooth Test 2023 Q4.txt (560 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 725286912 字节 (691.69 MB)
    MD5: 72a0f1186c7940808294eea6f3ee106b
    SHA1: 82e987a219c39bf67f969c35be200039e43109e2
    SHA256: 446bf564e2b334b1d787d62d64b95f68fa0c94ddba1e12bbf428cfea539c0fb3
    CRC32: 39f48b9e
    RFmx for Bluetooth Test 2023 Q4 Runtime.txt (593 Bytes, 下载次数: 0, 售价: 5 圆)
    2023Q4版未更新自述文件,参考2023Q3版
    RFmx for Bluetooth® Test 2023 Q3 Readme
    This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions.
    • RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx for Bluetooth® Test 2023 Q2 includes the following new features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.4, and the Bluetooth RF PHY test specifications RF.TS.p30e2 and RF-PHY.TS.p15.
    • Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.4
    RFmx for Bluetooth® Test 2023 Q1 includes the following new feature:
    RFmx for Bluetooth® Test 2022 Q4 includes the following new feature:
    • Support for DF2 and CFO measurements for Bluetooth LE 500kbps (S=2) packets
    • Support for PXIe-5842
    RFmx for Bluetooth® Test has the following requirements:
    RFmx for Bluetooth® Test 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 2023 Q3 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx for Bluetooth® Test (64-bit only)
    Required Software
    If you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.BTMX.Fx40.dll
    RFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » RFmx » BT palette.
    Documentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx for Bluetooth® Test Documentation.
    You can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx for Bluetooth® Test Examples.
    The following is the behavior change in RFmx Bluetooth® Test 2023 Q3 from RFmx Bluetooth® Test 2023 Q2
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q4 from RFmx for Bluetooth® Test 2022 Q3:
    • RFmx for Bluetooth® Test drops support for 32-bit user mode.
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q3 from RFmx for Bluetooth® Test 21.8.2:
    The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7.
    • Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
    GMT+8, 2026-1-14 07:17
