查看: 1482|回复: 0
[NI软件产品] NI Calibration Executive 2023 Q3 Win11 64bitEng NI校准执行程序23.5.0下载
    昨天 17:07
  • 签到天数: 3771 天
    连续签到: 22 天
     楼主| 发表于 2023-11-29 15:44:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    校准执行程序
    Calibration Executive用于校准和调整NI测量设备上的I/O通道。
    Calibration Executive是一个用于计量应用的软件工具。Calibration Executive提供了直观的用户界面,提供自动或手动两种模式。此外,该工具还提供了报告功能,用于记录校准和调整结果,同时还可存储和检索数据。借助软件的模块化环境,您可以在可用时添加新的校准程序,并将报告存储在符合ODBC的数据库中,以便从其他程序访问。
    该应用程序6.0之前的版本找不到完整版资源,无法提供。
    发布日期:2023/8/4
    包含的版本:2023 Q3完整版,版本号23.5.0
    文件大小: 11700121600 字节 (10.90 GB)
    修改日期: 2023-08-05 09:49
    MD5: dbe5245d16e05e89be00a41ebe9b1296
    SHA1: 09be4f9bbe0b8f51b89a429b622680d77ed96a41
    SHA256: ba0b48c0ba174b105cc50469d1774e13859ffcff9f8bd8d6eddf704fdfebf63f
    CRC32: 6fa987bd
    百度网盘和NI官方下载:
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    Calibration Executive 2023 Q3.txt (581 Bytes, 下载次数: 0, 售价: 20 圆)
    2023Q3版本未更新自述文件,参考上一版本6.9的自述文件
    Calibration Executive 6.9 Readme
    February 2023
    This file contains installation instructions and compatibility information for Calibration Executive 6.9.
    • Calibration Executive Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Calibration Executive Documentation: New features, behavior changes, and other documentation
    Upgrade Considerations
    Driver Information
    Calibration Executive 6.9 has the following requirements:
    • 1 GHz, 64-bit (x64) processor
    • 8 GB of RAM (procedures with a large number of test points might require more memory)
    • 1024 x 768 pixels screen resolution
    • The user must have administrator privileges
    Calibration Executive 6.9 supports the following operating systems:
    Download the Calibration Executive installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Calibration Executive requires Java SE 8 Update 51 or greater, which is available from www.oracle.com.
    If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation method of the Suite or Bundle.
    Calibration Executive versions 6.0 and later have a new installation path, and the program no longer launches as an administrator application. These changes can render some application database paths invalid after the upgrade. After an upgrade, you might need to manually move some files.
    Upgrading Calibration Executive 5.x to 6.0 and later
    If your Report and Uncertainty databases are in their default locations, the setup program will automatically move the databases to the new default location and no action is required.
    If databases were moved from their default locations in Calibration Executive 5.x, then Calibration Executive 6.x attempts to reference the current location. If Calibration Executive cannot write to the files in this location, a warning message will be displayed when you first launch Calibration Executive. In this case, you will need to move the files manually to a writeable location. After you move the database files, follow the instructions in Selecting Database Locations to configure the paths for Calibration Executive 6.0 and later.
    Upgrading Calibration Executive 4.x to 6.0 and later
    The setup program for Calibration Executive 6.x does not automatically move your Report and Uncertainty databases, even if they are in their default locations. Instead, you will need to move the databases manually to a writeable location. After you move the database files, follow the instructions in Selecting Database Locations to configure the paths for Calibration Executive 6.0 and later.
    To select the location of your Report database:
    • In the menu bar, select Configure»Database options.
    • Click the folder icon in the Calibration Executive Configure Report Database dialog, and browse to find the database file.
    • Select the file and click OK.
    • Click OK to close the dialog box.
    To select the location of your Uncertainty database:
    • In the menu bar, select Configure»Calibration Reports.
    • In the Calibration Reports window, click Manage Uncertainty. The Uncertainty Export/Import window opens.
    • Select Database Options»Select Database Location
    • Use controls in the Select Uncertainty Database File explorer window to locate your uncertainty database file.
    • Select the file, and click OK.
    • In the Uncertainty Export/Import window, click Done.
    • Click Close to close the Calibration Reports window.
    Driver Information
    The following instruments require specific drivers that are not installed by Calibration Executive. To install these drivers, you must download them directly from the manufacturer's website; you can find links to third party instrument drivers at ni.com/idnet.
    Driver versions listed are those tested during development; later versions might be available and should be compatible.
    Instrument
    Required Driver(s)
    Rohde & Schwarz NRP-Z power meterNRP-Toolkit 4.16
    NRP-NI-VISA Passport 2.7.1
    NRP-Z VXI Plug & Play x64 Driver 3.6.0.0
    Rohde & Schwarz SMA100A signal generatorVXIplug&play x64 driver rssma version 2.21.0
    Note  This release does not include an NI-VNA driver. To run the PXI-5691 and PXIe-5632 procedures, download NI-VNA 18.0 and install the driver manually after you install Calibration Executive.
    Product support and new features were added as indicated below:
    • Added driver support for Rohde & Schwarz NRP33S Power Sensor.
    • Product support:
      • NI 9262
    Calibration Executive 6.8
    • Product support:
      • PXIe-5163
      • PXIe-5698
    Calibration Executive 6.7
    • Product support:
      • FD-11613
      • FD-11614
      • NI 9210
      • NI TB-9212 with mini-TC
      • PXIe-4135 (40W)
      • PXIe-4137 (40W)
    Calibration Executive 6.6
    • Added driver support for Rohde & Schwarz SMA100B signal generator for procedures that previously supported the Rohde & Schwarz SMA100A.
    Calibration Executive 6.5
    • Product support:
      • PXIe-4139 (40W)
    Calibration Executive 6.4
    • Revised the reporting of guard band values with dB and dBv units on the calibration report.
    • Import uncertainties from an Open XML spreadsheet using formulas that result in text values.
    • Product support:
      • PXIe-5841
      • PXIe-5841 (2 yr)
      • RM-26999
    Calibration Executive 6.3
    • Revised formulas for determining measurement uncertainty related to TURs and nominal values.
    Calibration Executive 6.2
    • Product support:
      • PXIe-5624
      • PXIe-5606 Adjust Only
      • PXIe-5668 Adjust Only
      • USB-6346 (Screw Terminal)
      • STS-DIO-01
    Calibration Executive 6.1
    • Product support:
      • NI 9224
      • NI 9228
    • Uncertainty and guard band options in custom report configurations
    • Product support:
      • PXIe-6349
      • USB-6349
      • NI 9202
      • NI 9252
    The following procedures, features, and support were modified in Calibration Executive 6.x releases.
    Calibration Executive 6.8:
    • The following procedures have changed:
      • PXIe-5160 (2CH)
      • PXIe-5160 (4CH)
      • PXIe-5162 (2CH)
      • PXIe-5162 (4CH)
      • PXIe-5164
      • PXIe-5650
      • PXIe-5651
      • PXIe-5652
      • PXIe-5663E
      • PXIe-5673E 3.3GHz
      • PXIe-5673E 6.6GHz
    • Removed NI USB-5681 calibration procedure support
    • Removed NI USB-5684 power meter standard support
    Calibration Executive 6.7:
      • NI 9219
      • PXIe-4081 (90 day)
      • PXIe-4081 (2 yr)
      • PXIe-4137
      • RM-26999
    Calibration Executive 6.6:
      • PXIe-5160
      • PXIe-5162
      • PXIe-5644R
      • PXIe-5645R
      • PXIe-5646R
    Calibration Executive 6.5:
      • PXIe-4081 (2 yr)
      • PXIe-4135
      • PXIe-4139
      • PXIe-5840
      • PXIe-5841
      • NI 9212
    Calibration Executive 6.4:
    • Guard band calculation for uncertainties with dB and dBv units has changed.
      • PCI-4461
      • PXI-4461
      • PXIe-5654 (10 GHz)
      • PXIe-5654 (20 GHz)
      • PXIe-5654 with PXIe-5696 (10 GHz) Adjust Only
      • PXIe-5654 with PXIe-5696 (20 GHz)
      • PXIe-5668 (14 GHz), all bandwidth options
      • PXIe-5840
      • PXIe-5840 (2 yr)
      • NI 9220
      • NI 9263
    Calibration Executive 6.3:
    • TUR calculation for uncertainties with dB and dBv units has changed.
      • PXIe-4135
      • PXI-5422
    Calibration Executive 6.2:
    • PXI-4110
    • PCI-5412
    • PXI-5412
    • PCI-5421
    • PXI-5421
    • PXI-5441
    • PXIe-5442
    • PXIe-5653
    • PXIe-5665 (3.6 GHz)
    • PXIe-5665 (3.6 GHz), no pre-amp
    • PXIe-5665 (14 GHz)
    • PXIe-5668 (26.5 GHz), all bandwidth options
    Calibration Executive 6.1:
    • PXI-4110
    • USB-5132
    • USB-5133
    • PCI-5412
    • PXI-5412
    • PCI-5421
    • PXI-5421
    • PXI-5441
    • PXIe-5442
    • PXI-5622
    • PXIe-5645R
    • PXIe-5654 (20 GHz), with PXIe-5696
    Calibration Executive 6.0.1:
    • A critical bug in the Verify ALC Limits Table test is fixed, enabling the following devices to be verified and adjusted:
      • PXI-5650
      • PXIe-5650
      • PXI-5651
      • PXIe-5651
      • PXI-5652
      • PXIe-5652
      • PXIe-5663
      • PXIe-5663E
      • PXIe-5673
      • PXIe-5673E
    Calibration Executive 6.0:
    • Added adjustment support for NI 9203.
    • Modified audio notifications can only be enabled or disabled; there are no additional options to be configured.
    • Removed support for 32-bit OS calibration procedures.
    Refer to the Calibration Executive documentation, accessible from strong>Help»Calibration Executive Help, for information about Calibration Executive.
    Calibration Executive no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-14 07:17
