查看: 1532|回复: 0
[NI软件产品] NI RFmx SpecAn/Power Amplifier/Phase Noise/Niose Figure 2023 Q3 Win11 64bitENG RFmx频谱分析仪/功率放大器/相位噪声/噪声系数23.5.0
     楼主| 发表于 2023-9-3 16:38:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版/运行版,版本号23.5.0
    64位完整版校验和:
    文件大小: 1535033344 字节 (1.43 GB)
    修改日期: 2023-07-19 09:55
    MD5: 02e5e7391ddbead9c40e24c4f4ea147b
    SHA1: ed433c65b4600f0d16442ed73d4a55e439efc26d
    SHA256: 2c1f5487bfac5a77306ab3ff84b799d8d9b464941d9fc5d4e097283550baa59d
    CRC32: 026b6210
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx SpecAn2023Q3.txt (595 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 678596608 字节 (647.16 MB)
    修改日期: 2023-07-19 09:56
    MD5: 08a3d69029e1465b8152e965b11397bc
    SHA1: dfc043ad8e8ec46c16ab86242300ea09c311ae40
    SHA256: e3141b691c1a51c639a6c6b0eda142d669e63a1fda47e38f3011f387283317ad
    CRC32: 6d32fd02
    RFmx SpecAn2023Q3Runtime.txt (628 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx SpecAn 2023 Q3 Readme
    This file contains important information about the RFmx SpecAn, including system requirements, and installation instructions.
    • RFmx SpecAn Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx SpecAn Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx SpecAn 2023 Q3 includes the following new features:
    • Iterative Learning Control for DPD measurement
    • Support for Noise Compensation in ACP measurement for Sequential FFT mode
    RFmx SpecAn 2023 Q2 includes the following new features:
    • Support for Detectors in CHP and ACP measurements
    RFmx SpecAn 2023 Q1 includes the following new feature:
    RFmx SpecAn has the following requirements:
    RFmx SpecAn 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx SpecAn no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx SpecAn 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx SpecAn 2023 Q3 to an unsupported OS. Additionally, after installing RFmx SpecAn 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx SpecAn
    LabWindows™/CVI™2019 or later
    Required Software
    • NI-RFSG 14.0.1 or later
    • NI-RFSG Playback Library 19.1 or later (for DPD examples)
    Download the RFmx SpecAn installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • RFmx SpecAn installs the following licensed products
      • RFmx Noise Figure: This will enable the Noise Figure measurement in RFmx SpecAn.
      • RFmx Phase Noise: This will enable the Phase Noise measurement in RFmx SpecAn.
      • RFmx Power Amplifier: This will enable the AMPM and DPD measurements and the Crest Factor Reduction (CFR) support in RFmx SpecAn.
    • Use the serial number that is included with your software to activate the product. Refer to the NI Software Activation for more information on product activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx SpecAn palette VIs are available from the Functions » Measurement I/O » NI-RFmx » SpecAn palette.
    Documentation for RFmx SpecAn is located at Start » National Instruments » RFmx SpecAn Documentation.
    Select Help » Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output » Modular Instruments » NI-RFmx » SpecAn. You can also select the Search tab to search all installed examples by keyword.
    You can access all the installed RFmx SpecAn examples at Start » National Instruments » RFmx SpecAn » RFmx SpecAn Examples.
    The following is the behavior change in RFmx SpecAn 2023 Q3 from RFmx SpecAn 2023 Q2
    The following is the behavior change in RFmx SpecAn 2022 Q4 from RFmx SpecAn 2022 Q3:
    • RFmx SpecAn drops support for 32-bit user mode.
    The following is the behavior change in RFmx SpecAn 2022 Q3 from RFmx SpecAn 21.8.2:
    The following are the behavior changes in RFmx SpecAn 20.7 from RFmx SpecAn 20.6.
    GMT+8, 2026-1-13 13:11
