查看: 632|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2023 Q3 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试23.5.0
    3 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-9-2 14:55:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版/运行版,版本号23.5.0
    64位完整版校验和:
    文件大小: 1389453312 字节 (1.29 GB)
    修改日期: 2023-07-19 09:56
    MD5: 4bf56be4e61cae1d8d8c479c198cecd5
    SHA1: 663ed009780912a7368cd7d676b46a443e7403e7
    SHA256: d2d06119fa2a5cc10a2dfa2ccbdacb676160a25a9511b436971bf24dd7da4d45
    CRC32: 3b6db6c5
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx W-CDMA2023Q3.txt (542 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 671229952 字节 (640.13 MB)
    MD5: 48063651c8dd6886f1593bc9c0d62c91
    SHA1: 2f0db23829457718272fed7f3512d3468c8ca892
    SHA256: 3e297167b0492b327de873db691840b7dc3013c69dc99468bc5704f696ce2ba2
    CRC32: 4e6004e6
    RFmx W-CDMA2023Q3Runtime.txt (575 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx WCDMA 2023 Q3 Readme
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx WCDMA 2023 Q2 includes the following new feature:
    RFmx WCDMA 2023 Q1 includes the following new feature:
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    Required Software
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2023 Q3 from RFmx WCDMA 2023 Q2
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    GMT+8, 2025-5-10 13:33
