查看: 790|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q3 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.5
    3 天前
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2023-9-1 10:06:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q3
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版,版本号23.5.0
    文件大小: 5009932288 字节 (4.67 GB)
    修改日期: 2023-07-19 09:56
    MD5: 40d501d6c0c4cf2b97ffd1cb47a80f6a
    SHA1: 713c2f98017a8b19012c7a6f17eaf95b7bb534aa
    SHA256: 206841cbb6324aa414d706abe0cfc388e67defc42eb70e0cefc5cb8aebba32b0
    CRC32: a6cae4bd
    RFSG2023Q3.txt (514 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2025-6-3 06:14
