查看: 763|回复: 0
[NI驱动程序] NI System Configuration 2023 Q3 Mac64bitEng NI系统配置nisyscfg23.5苹果版
    3 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-8-30 09:39:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    System Configuration系统配置
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版,版本号23.5.0
    macOS
    语言:英文English
    校验和
    文件大小: 16244410 字节 (15.49 MB)
    修改日期: 2023-07-16 09:50
    MD5: a626ea8c2d180538f2326bd56be92aed
    SHA1: 2dfda1b7ed040c712c434f47de6e0f1437a53311
    SHA256: f215b559e3b79f0ce071fedb43f8122aac14845a9984800108dc57a3b5bc0657
    CRC32: df9fcad2
    系统配置2023Q3mac.txt (500 Bytes, 下载次数: 0, 售价: 10 元)
    System Configuration 2023 Q2 for macOS Readme
    April 2023
    This file contains installation instructions and compatibility information for System Configuration for macOS.
    List of Features not Supported in macOS
    System Configuration includes NI Measurement & Automation Explorer (MAX), a configuration utility that provides access to your NI devices.
    System Configuration has the following requirements:
    • OS versions: macOS 11, macOS 12 (x86_64 only)
      Note System Configuration was verified with the specified operating systems.
    • At least 60 MB of disk space
    The following table lists the NI application software versions, including service packs, supported by System Configuration.
    Versions Supported by System Configuration
    NI LabVIEW2019, 2020, 2021, 2022 Q3 and later
    The "System Configuration Support for LabVIEW" package supports applications using System Configuration ?with LabVIEW 2022 Q3 or later. When installing System Configuration, this package will be recommended if you have already installed LabVIEW 2022 Q3 or later and installs to the LVAddons directory.
    LVAddons directory location: /Library/Application Support/National Instruments/LVAddons
    The following VIs in the System Configuration API that are supported with RT targets on Windows are not supported on macOS:
    • Get Available Software VI
    • Install VI
    • Uninstall VI
    © 2014–2023 National Instruments Corporation. All rights reserved.
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    GMT+8, 2025-5-10 13:08
