查看: 757|回复: 0
[NI软件产品] NI mmWave OTA Validation Test Software 23.0 x64Win10 64bitEng NI毫米波空口验证测试软件23.0
    昨天 08:12
  • 签到天数: 3548 天
    连续签到: 18 天
     楼主| 发表于 2023-8-28 10:41:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    mmWave OTA验证测试软件
    mmWave OTA验证测试软件可简化并加速5G封装天线波束成形器件的特性分析和验证测试。
    mmWave OTA验证测试软件是一款应用软件,可帮助您配置、运行、可视化和报告5G mmWave封装天线集成电路(IC)空口(OTA)辐射性能。该软件可以执行系统校准,以测量每个信号路径的路径损耗,进而补偿测试仪器、电缆、天线和空口通信。此外,mmWave OTA验证测试软件还根据3GPP测试规范简化了配置和运行3D空间扫描的过程。您可以使用模板自定义测试序列,以自动执行数据采集、结果报告和存储。该软件包括一系列可视化工具,包括天线方向图、3D和极坐标图、波束宽度、热图等。
    发布日期:2023/5/29
    包含版本:23.0.0完整版(此版本只支持到LabVIEW2021SP1,并不支持LabVIEW2023Q1,即LV23.0。而有些模块驱动软件则又是需要2023Q1版。请查看Readme自述文件了解清楚)
    受支持的操作系统
    语言:英文
    文件大小: 810881024 字节 (773.32 MB)
    修改日期: 2023-05-29 21:50
    MD5: 763604db4bf9b7f634cef4a5c5e0bc14
    SHA1: 825777b4b39bacef4b75033c0f48d2b4b4726734
    SHA256: 901785858170b24d376cd0bd6adb13c36aa185a506bbea12d77b633e58d06d97
    CRC32: d4af7415
    请注册登录视觉论坛账号,购买附件查看下载地址
    mmWave OTA Validation Test Software23.0.txt (633 Bytes, 下载次数: 0, 售价: 10 元)
    mmWave OTA Validation Test Software 23.0 Readme
    May 2023
    This file contains installation instructions and compatibility information for mmWave OTA Validation Test Software 23.0.
    • mmWave OTA Validation Test Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Required Software
    Finding Installed Software
    This software installation provides support for the mmWave OTA Validation Test Reference Architecture and helps you configure, run, visualize, and report the over-the-air (OTA) radiated performance of 5G mmWave antenna-in-package (AiP) integrated circuits.
    mmWave OTA Validation Test Software can perform system calibration to measure the path losses of every signal path, compensating for test instruments, cables, antennas, and air interface. Additionally, mmWave OTA Validation Test Software simplifies the process of configuring and running 3D spatial sweeps according to 3GPP test specifications. You can use templates to customize test sequences to automate data collection, results reporting, and storage. The software also includes a collection of visualization tools for antenna pattern cuts, 3D and polar plots, beamwidth, heat map, and more.
    mmWave OTA Validation Test Software 23.0 adds the following new feature:
    • Extends measurement frequency to 50 GHz by adding support for PXIe-5842 Vector Signal Transceiver with 54 GHz Frequency Extension
    Required Software
    mmWave OTA Validation Test Software 23.0 requires the following software versions.
    Software
    Required for LabVIEW Support
    Required for TestStand Support
    Required for C# .NET Support
    Required for MATLAB Support
    Required for Python Support
    LabVIEW 2021 SP1(64-bit)
    LabVIEW 2021 SP1 Runtime Engine (64-bit)
    TestStand 2021 (64-bit)
    Microsoft Visual Studio†  2017+
    MATLAB† 2020b
    Python† 3.10
    RFmx NR 2023 Q1
    RFmx SpecAn 2023 Q1
    NI-DAQmx 2023 Q1
    NI-RFSA 2023 Q1
    NI-RFSG 2023 Q1
    NI-RFSG Playback Library 2023 Q1
    †  If you are using the mmWave OTA Validation Test C# .NET API, MATLAB examples, and Python examples, .NET Framework 4.6.2 (minimum) is required. To use the .NET API, you must also install .NET support for the required drivers.
    Refer to the documentation of each software product for specific system requirements.
    mmWave OTA Validation Test Software 23.0 supports Windows 10 (64-bit).
    Download the mmWave OTA Validation Test Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Note  Use the serial number that is included with your software to activate mmWave OTA Validation Test Software. For more information on mmWave OTA Validation Test Software activation, refer to Activating a Product.
    mmWave OTA Validation Test Software supports the mmWave OTA Validation Anechoic Chamber, the MilliBox™ Chambers and positioners, and all instruments used with the mmWave OTA Validation Test Reference Architecture. Refer to the mmWave OTA Validation Test Reference Architecture Manual for a full list of supported instruments.
    The mmWave OTA Validation Test Reference Architecture Manual is restricted on ni.com. Refer to the installed documentation for how to access the online library for user documentation for using mmWave OTA Validation Test Software. The mmWave OTA Validation Test Reference Architecture documentation is accessible from Start»National Instruments»OTA Documentation.
    Item
    Installed Location
    mmWave OTA TestStand ExamplesUsers\Public\Public Documents\National Instruments\TestStand 2021 (64-bit)\Examples\OTA Test
    mmWave OTA Validation Configurator\National Instruments\OTA Test\Configurator
    mmWave OTA Validation Positioner Control Panel\National Instruments\OTA Test\Positioner
    mmWave OTA Support for LabVIEW\National Instruments\LabVIEW 2021\user.lib\OTA Test
    mmWave OTA Support for .NET, MATLAB, and PythonUsers\Public\Public Documents\National Instruments\OTA Test\Examples
    mmWave OTA Validation Visualizer\National Instruments\OTA Test\Visualizer
    mmWave OTA Validation Antenna Alignment Helper\National Instruments\OTA Test\Antenna Alignment
    RF System Calibration Assistant\National Instruments\RF System Calibration
    举报
    GMT+8, 2025-5-24 17:20
