查看: 790|回复: 0
[NI软件套件] NI Test Workflow 2023 Q3 Pro Win11 32/64bitEng NI测试工作流程23.5专业版-32/64位英文专业版
    14 小时前
  • 签到天数: 3559 天
    连续签到: 4 天
     楼主| 发表于 2023-8-24 10:04:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Test Workflow测试工作流程
    专业版包含:
    应用程序软件
    LabVIEW专业版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem专业版
    TestStand
    附加软件
    LabVIEW VI Analyzer工具包
    发布日期:2023/7/18
    包含的版本:2023 Q3专业版,版本号23.5.0
    语言:英文English
    文件大小: 11316385792 字节 (10.54 GB)
    修改日期: 2023-07-19 09:52
    MD5: 5e00cdb0978b57093acdd01377e99146
    SHA1: 161fa38e0144c6af3f98365886380d0137f9e431
    SHA256: 6e712d0d11ec606a193f8844a2ac038e3ed3c2f0174ff7ab7011ee9fe9072e17
    CRC32: 4b3750d5
    注册登录视觉论坛,购买附件查看下载地址
    Test Workflow2023Q3ProEng.txt (606 Bytes, 下载次数: 0, 售价: 30 元)
    Test Workflow 2023 Q1 Pro Readme
    January 2023
    This file contains installation instructions and compatibility information for Test Workflow 2023 Q1 Pro.
    • Test Workflow Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Test Workflow Pro Bundle
    Test Workflow 2023 Q1 Pro supports the following operating systems:
    The following products are included in the Test Workflow Pro installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    DIAdem2022 Q464-bit
    FlexLogger2023 Q1164-bit
    InstrumentStudio2023 Q164-bit
    1FlexLogger 2023 Q1 does not support 2023 Q1 NI driver software.
    If you are using the Test Workflow .NET Class Library, .NET Framework 4.0 (minimum) is required. The Test Workflow 2023 Q1 Pro .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Test Workflow installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow. For more information on Test Workflow activation, refer to Activating a Product.
    Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-6-6 22:41
