查看: 793|回复: 0
[NI软件套件] NI Test Workflow 2023 Q3 Standard Win11 32/64bitEng NI测试工作流程23.5标准版-32/64位英文完整版
    14 小时前
  • 签到天数: 3559 天
    连续签到: 4 天
     楼主| 发表于 2023-8-24 09:54:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Test Workflow测试工作流程
    标准版包含:
    应用程序软件
    LabVIEW完整版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem高级版
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版/标准版 版本号23.5.0
    语言:英文English
    文件大小: 9999998976 字节 (9.31 GB)
    修改日期: 2023-07-19 09:59
    MD5: d0eec8692063616756d99ef91033264a
    SHA1: d6ccf39080d303876ef79886bb651dcd9026ac4b
    SHA256: 9c0b6036da5af143f1b32a92b6a3a22c42d1c5f225444bc72cc1f7aa20b28fa0
    CRC32: 54994e36
    Test Workflow2023Q3FallEng.txt (620 Bytes, 下载次数: 1, 售价: 20 元)
    2023Q3版未更新自述文件,参考2023Q1版
    Test Workflow 2023 Q1 Standard Readme
    January 2023
    This file contains installation instructions and compatibility information for Test Workflow 2023 Q1 Standard.
    • Test Workflow Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Test Workflow Standard Bundle
    Test Workflow 2023 Q1 Standard supports the following operating systems:
    The following products are included in the Test Workflow Standard installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    DIAdem2022 Q464-bit
    FlexLogger12023 Q164-bit
    InstrumentStudio2023 Q164-bit
    1FlexLogger 2023 Q1 does not support 2023 Q1 NI driver software.
    If you are using the Test Workflow .NET Class Library, .NET Framework 4.0 (minimum) is required. The Test Workflow 2023 Q1 Standard .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Test Workflow installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow. For more information on Test Workflow activation, refer to Activating a Product.
    Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-6-6 22:31
