查看: 1181|回复: 0
[NI软件产品] NI InstrumentStudio 2023 Q3 Win11 64bitEng NI仪器套件2023Q3 InstrumentStudio23.5.0
     楼主| 发表于 2023-8-23 09:50:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    InstrumentStudio
    InstrumentStudio是一款免费的应用程序软件,提供了集成的交互式PXI测量方法。
    InstrumentStudio可帮助您统一显示数据,将仪器配置导出到代码,并监测和调试您的自动测试系统。 您可以使用大型高分辨率显示器在统一显示界面上查看数据,然后捕获多仪器屏幕截图和测量结果。 您还可保存项目级配置,以便针对特定的待测设备更轻松地重复进行测试,或将仪器配置导出到编程环境,以简化代码并保证测量相关性。您还可以同时使用代码和InstrumentStudio来监测和调试正在运行的测试应用程序。
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版,版本号23.5.0
    文件大小: 1087086592 字节 (1.01 GB)
    修改日期: 2023-07-19 09:51
    MD5: d3d0fa6ba30821a6188f5584814f1d08
    SHA1: aa93a629b55a840c47bab26605f871a0c7a08866
    SHA256: a0d0f5a75f7b169e4dc66fb25e9e88f6a7abe723550fc2283e86b1b24975d687
    CRC32: f1d1c49a
    请注册登录机器视觉论坛,购买附件后查看下载地址
    InstrumentStudio2023Q3.txt (559 Bytes, 下载次数: 0, 售价: 10 圆)
    2023Q3版未更新自述文件,参考2023Q2版
    InstrumentStudio 2023 Q2 Readme
    April 2023
    This file contains installation instructions and compatibility information for InstrumentStudio 2023 Q2.
    • InstrumentStudio Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • InstrumentStudio Documentation: Detailed documentation about how to use your product
    InstrumentStudio 2023 Q2 has the following requirements:
    • Pentium 4 G1 equivalent or later (Intel i5 equivalent or higher recommended)
    • At least 10 GB of disk space
    • 4 GB RAM
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    InstrumentStudio 2023 Q2 supports the following operating systems:
    InstrumentStudio 2023 Q2 supports the following application software versions, including service packs.
    Device Drivers
    Versions Supported by InstrumentStudio 2023 Q2
    NI-SCOPE20.7
    NI-FGEN19.1
    NI-DMM18.1
    NI-DCPOWER2023 Q1
    NI-RFSG21.5
    RFmx2023 Q1
    Download the InstrumentStudio installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    • Added LTE, NR and WLAN personality support for remote RF Signal Analyzer panels as a preview feature
    Refer to the InstrumentStudio documentation, accessible from ni.com/docs, for information about InstrumentStudio.
    InstrumentStudio no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-13 11:00
