查看: 1739|回复: 0
[Patch补丁] LabVIEW 2013 FPGA Module F1 Patch Win32Eng LabVIEW2013FPGA模块f1补丁
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 2023-5-11 18:48:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    文件名: 2013FPGA f1 Patch.iso
    文件大小: 35840000 字节 (34.18 MB)
    修改日期: 2013-09-23 13:41
    MD5: 88db8c0f0336a1ffbbd532cce65d4347
    SHA1: 9999b1f091b247000dc519e4491333ed617ae0c6
    SHA256: 65f3cfecb18ed2824e0f75706f2b587cae1726e8d86a1ab9c318d610882de014
    CRC32: ff5afd6f
    FPGA2013F1Patch.txt (390 Bytes, 下载次数: 0, 售价: 5 圆)
    * readme.txt
    * NI LabVIEW 2013 FPGA Module f1 Patch
    * Date: August 15, 2013
    Summary:
    This patch addresses two issues with LabVIEW FPGA simulation on the desktop computer. The first fixed issue addresses performance degredation during simulation on the desktop computer for certain LabVIEW FPGA designs. The second fix addresses a hang that may occur when running multiple simulations on the desktop computer.
    Installation Instructions:
    Run the provided installer, setup.exe
    LabVIEW 2013 FPGA Module Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW FPGA Module, including:
    Installation
    NI LabVIEW FPGA Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    Important Information
    The development computer is a PC or NI PXI/PXI Express system on which you install LabVIEW and the LabVIEW FPGA Module. You can use this computer to compile FPGA VIs, but if the FPGA design or target requires more than 2 GB of memory, National Instruments recommends installing the LabVIEW FPGA compilation tools on a separate computer. This computer is referred to as the remote compile server.
    Development Computer
    • LabVIEW 2013 Full or Professional Development Systems (32-bit)
    • 11 GB additional disk space
    • Memory1:
      • At least 4 GB of RAM for Virtex-6 and later2 FPGA targets
      Note: The LabVIEW 2013 FPGA Module does not support Windows 8.
      • Windows 7 (32-bit)
      • Windows 7 (64-bit with 32-bit LabVIEW installed)
      • Windows Vista (32-bit)
      • Windows Vista (64-bit with 32-bit LabVIEW installed)
      • Windows XP Pro (Service Pack 3)
      • Windows Server 2003 R2 (32-bit)3
      • Windows Server 2008 R2 (64-bit with 32-bit LabVIEW installed)
    • FPGA device
    • Device driver software—To program most devices with the LabVIEW 2013 FPGA Module, install the NI-RIO 13.0 driver software. Refer to the hardware documentation for different requirements for a specific device.
    1Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target. To determine your memory needs, monitor the memory usage of the xst.exe process in the Windows Task Manager.
    2You must use a 64-bit OS to address 4 GB of RAM.
    3The LabVIEW FPGA Module does not support the Windows Server non-R2 editions.
    Installation
    You can install all of your LabVIEW products—including the FPGA Module–using the LabVIEW 2013 Platform DVDs. You can find installation instructions for the FPGA Module along with activation instructions in the following locations:
    • LabVIEW FPGA Module Release and Upgrade Notes, which are available in your FPGA Module software kit or online at ni.com/manuals.
    • LabVIEW 2013 Installation Guide, which is available in your LabVIEW software kit.
    • LabVIEW 2013 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    • Activation Instructions for National Instruments Software, which are available on the LabVIEW intallation media.
    To request additional LabVIEW 2013 Platform DVDs, refer to the National Instruments website.
    LabVIEW FPGA Module Updates and Notifications
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2013 FPGA Module.
    395895Compile worker does not filter out worker-specific properties
    The National Instruments LabVIEW FPGA Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the LabVIEW FPGA Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2003–2013 National Instruments. All rights reserved.
    I.     Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    II.     Third-Party Copyright Notices
    \National Instruments\LabVIEW 2013\FPGA\Legal\
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2026-4-1 12:39
