查看: 1706|回复: 0
[LV工具模块] LabVIEW 2013 LEGO MINDSTORMS NXT Module Win32Eng
     楼主| 发表于 2023-5-11 17:50:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LEGO MINDSTORMS Module for LabVIEW
    LEGO MINDSTORMS Module模块用于帮助学生使用基于LEGO MINDSTORMS EV3和NXT的机器人。
    LEGO MINDSTORMS模块是用于LabVIEW的一款系统工程软件,学生可以在教室或机器人竞赛中结合LEGO Education机器人平台使用该软件。该软件可作为教学工具,帮助学生对LEGO MINDSTORMS机器人进行视觉控制和编程。LEGO MINDSTORMS模块可以将任何LEGO MINDSTORMS Education平台改造为科学和工程学习平台。该模块还提供包括教程和交互式练习,旨在帮助学生进一步提高LabVIEW技能。LEGO、LEGO商标和MINDSTORMS是LEGO集团的注册商标。 版权.2020 the LEGO Group。
    文件大小: 120652576 字节 (115.06 MB)
    修改日期: 2023-05-11 16:50
    MD5: 3014942a9e80575ebe67170947eaffd2
    SHA1: 90be678c187f58dc17096e863391d744350ee6e7
    SHA256: 307e15259595de57c89d28dfdcc660a01ae908d4bce0c7450dad6964ee2b8ca3
    CRC32: 074b2da2
    NXT2013.txt (526 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2013 LEGO® MINDSTORMS® NXT Module Readme for Windows
    August 2013
    This file contains information about the LabVIEW NXT Module, including a partial list of bugs fixed for the LabVIEW NXT Module and known issues.
    Finding Applications and Examples
    Use the LabVIEW NXT Module to create VIs that either run directly on an NXT brick or that run on a host computer and communicate with an NXT brick through a USB, Bluetooth, or Wi-Fi connection.
    The LabVIEW 2013 NXT Module requires the LabVIEW 2013 Full or Professional Development System.
    Refer to the LabVIEW 2013 Readme on the National Instruments website for information about system requirements for LabVIEW 2013.
    The following items are the IDs and titles of a subset of issues fixed for the LabVIEW NXT Module. This is not an exhaustive list of issues fixed in the current version of the LabVIEW NXT Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    100634LabVIEW VIs cannot download to two NXT bricks with the same name.
    189871Parallel loops in a Sequence structure do not execute in parallel when executed on NXT bricks
    189870VIs targeted to an NXT brick that contain multi-frame Flat Sequence structures return error code 1003
    Refer to the National Instruments website for a list of bug fixes in LabVIEW 2013.
    The following list describes known issues at the time of release:
    • A LabVIEW crash, an error message about Fantom.dll, and inconsistent behavior from the NXT Terminal are all consequences of deleting dependencies of Fantom.dll. To correct this behavior, navigate to the Control Panel\Programs\Programs and Features directory, and repair the LEGO MINDSTORMS NXT Driver installation.
    • After you connect to an NXT brick using Bluetooth, the NXT Terminal displays the NXT brick as available for connection when the Bluetooth connection is turned off. Manually remove the NXT brick from the NXT Terminal to remove the connection option.
    • Any calibration you perform on the NXT brick is not taken into account when you read sensor values using the direct command protocol.
    • Moving returns TRUE only when performing a move with the Move a Fixed Distance VI. These Boolean outputs always return FALSE if the move initiates with the Move DC Motors VI.
    • Tones specified below 220 Hz sound the same on the NXT brick.
    • The following code is not supported in VIs that you download to an NXT brick:
      • Byte Array To String functions if you try to coerce a 32-bit array
      • Some auto-indexing capabilities on While Loops—Auto-indexing input tunnels are supported.
      • Numeric operations involving a cluster and an array of clusters
      • Not function if you try to negate an array
      • Divide function if both inputs are zeros—Divide function returns zero instead of NaN.
      • Conversion functions if you try to convert floating point numbers to integers—Outputs are truncated instead of rounded to the nearest integer.
      • Conditional terminals or parallelism on For Loops
      • Formula Nodes
    • The Value property does not update front panel objects. Use local variables or wire values directly to terminals to update front panel objects.
    • If a VI targeted to an NXT is open when you change environments by selecting Tools»Choose Environment, the menus of that VI become unresponsive. Click the X in the corner of the VI window to close the VI.
    • Filenames with special or multibyte characters are not supported in the Robot Project Center.
    • Unexpected behavior can occur in the Schematic Editor when you work on a remote desktop.
    • When adding an image for your robot project profile, use an image that is 123 × 89 pixels (width × height).
    Refer to the following documents for more information about the LabVIEW NXT Module:
    • LabVIEW NXT Module Help—Use the LabVIEW NXT Module Help to access information about NXT Module programming concepts, step-by-step instructions for using the NXT Module, and reference information about the NXT VIs, palettes, menus, dialog boxes, and so on. Access the LabVIEW NXT Module Help by selecting Help»NXT Module Help.
    • LabVIEW Help—Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about advanced LabVIEW concepts and procedures.
    Select Tools»NXT Applications to access applications that you can run on an NXT brick. These applications demonstrate several types of programs you can create with the LabVIEW NXT Module.
    Access example VIs that demonstrate common tasks using the LabVIEW NXT Module in the NI Example Finder by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules»NXT in the NI Example Finder window. You also can access these VIs by referring to the labview\examples\NXT Robotics directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    Important Information
    © 2009–2013 National Instruments. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks.
    LEGO and MINDSTORMS are trademarks of the LEGO Group. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2026-1-13 12:45
