查看: 1226|回复: 0
[NI软件产品] NI VeriStand Custom Devices 2023 Q2 Win11 32/64bitEng NI VeriStand自定义设备23.3
    昨天 08:56
  • 签到天数: 3596 天
    连续签到: 4 天
     楼主| 发表于 2023-5-8 15:25:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VeriStand Custom Devices自定义设备
    VeriStand Custom Devices为VeriStand添加了硬件支持。
    VeriStand Custom Devices是VeriStand的附加软件工具。该附加软件为HIL测试应用的其他硬件和总线类型提供支持。您可以使用VeriStand System Explorer来配置自定义设备,以满足实时测试应用的需求。VeriStand Custom Devices包括以下自定义设备:数据共享框架;嵌入式数据记录仪;发动机仿真工具包;FPGA附加软件;仪器附加软件;路由和故障分析(NI-SWITCH和SLSC开关);扫描引擎和EtherCAT;SLSC 12201;SLSC EDS;同步;以及Telemetry和System Monitor。
    发布日期:2023/4/11
    包含的版本:2023 Q1完整版,版本号23.3.0
    文件大小: 686532608 字节 (654.73 MB)
    修改日期: 2023-04-12 09:54
    MD5: cca4b3bf5081d1288ffa7141ffb9464a
    SHA1: aed1c074034e40a62f6628aae0d406174004fe0c
    SHA256: 932ff0fe29f2546fe41d201edc2a0db3a818c578769c3efc21864d034261a114
    CRC32: 9eaf83d9
    请注册登录视觉论坛账号,购买附件查看下载地址
    VeriStand自定义设备2023Q2.txt (607 Bytes, 下载次数: 0, 售价: 10 元)
    官方没有针对VeriStand Custom Devices的自述说明,使用的是Veristand的自述文件。
    VeriStand 2023 Q2 Readme
    April 2023
    This file contains installation instructions and compatibility information for VeriStand 2023 Q2.
    • VeriStand Documentation: Detailed documentation about how to use your product
    VeriStand 2023 Q2 installs with the following:
    • NI-DAQmx 2023 Q2
    • NI-VISA 2023 Q2
    • NI-SLSC 2022 Q4
    • NI-XNET 2023 Q2
    • NI R Series Multifunction RIO 2023 Q2
    Simulation Models
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    VeriStand 2023 Q2 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 11 64-bit version 22H2
    • Windows 10 64-bit version 22H21
    When formatting a disk with a PXI Linux RT system image for VeriStand 2023 Q2, select Linux RT System Image 2023 Q2 and enable support for the LabVIEW 2023 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2023 Q2.
    Note  NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2023 Q2. To access the documents, refer to the VeriStand Release Notes.
    Primary Control Loop (PCL) Timing Source
    As of VeriStand 2023 Q2, the System Explorer default for the PCL DAQ timing source is Signal From Task (Sample Complete). This default applies to new projects under the following conditions:
    • Setting the timing source to DAQ Timing.
    • Setting the timing source to Automatic Timing when a NI-DAQ device has at least one analog input hardware-timed single point channel.
    Note  This behavior will not change for existing, upgraded projects.
    Uncompiled Models
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions.
    Note  Models built with LabVIEW 2023 Q1 and later no longer support simulation subsystems developed using the LabVIEW Control Design and Simulation Module add-on.
    Migrating Files from VeriStand 2010 through 2018 SP1
    VeriStand 2023 Q2 can open projects from VeriStand 2010 through 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    LabVIEW can no longer automate actions with legacy stimulus profiles. Consider migrating to modern stimulus profiles and real-time sequences.
    In addition, the following LabVIEW automation VIs are deprecated and no longer included with VeriStand:
    • NI VeriStand - Get Alarm Status.vi
    • NI VeriStand - Get Engine State.vi
    • NI VeriStand - Lock Workspace File.vi
    • NI VeriStand - Run Workspace File.vi
    • NI VeriStand - Stop Workspace File.vi
    • NI VeriStand - Unlock Workspace File.vi
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q2 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q2 .NET API Help.
    • VeriStand Project — An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\VeriStand 2023\Projects\Example directory.
    • Stimulus Profile Editor — VeriStand Stimulus Profile Editor examples are located in the \National Instruments\VeriStand 2023\Examples directory.
    • ASAM XIL and Custom Device Sample Configurations — Configuration examples for ASAM XIL and custom devices are located in the \National Instruments\VeriStand 2023\Examples directory.
    • LabVIEW API — LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2023\examples\NI VeriStand directory or in the \National Instruments\LabVIEW 2023\examples\NI VeriStand Custom Devices directory.
    GMT+8, 2025-7-18 09:08
