查看: 829|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2023 Q2 Win11 32/64bitEng NI-RFSG回放库23.3
    8 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-5-8 11:16:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    语言:英文English
    32/64位完整版校验和:
    文件大小: 599801856 字节 (572.02 MB)
    修改日期: 2023-04-12 09:54
    MD5: 2465faeec6f8c93d893d69b6818295d9
    SHA1: 3880347bf8615e434cb75d53690fb03c49e98675
    SHA256: dff51998711a942f9f2e196b111e0800a33a5ac770fc9c7617a8f57a6bd75bb3
    CRC32: a659e9c7
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFSGPlayback2023Q2.txt (583 Bytes, 下载次数: 0, 售价: 10 元)
    32/64位运行版校验和:
    文件大小: 447406080 字节 (426.68 MB)
    MD5: a8bbb4e55d5095cce0842a0771b87089
    SHA1: 48b8d1349056da97867002bcc8f7a7297e06949a
    SHA256: 6da6a5a62bfd3f034ec22b106c0404927bde3e37efff7f41f0fdcb1205eaee81
    CRC32: 27a7f725
    RFSGPlayback2023Q2RTE.txt (615 Bytes, 下载次数: 0, 售价: 5 元)
    NI-RFSG Playback Library 2023 Q2 Readme
    April 2023
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    • NI-RFSG Playback Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Playback Library Manuals: New features, behavior changes, and other documentation
    Installed Software
    NI-RFSG Playback Library 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1 (32-bit and 64-bit)
    NI-RFSG Playback Library 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    NI-RFSG Playback Library 2022 Q3 includes the following new features:
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 2023 Q2 supports the following 64-bit operating systems:
    Note    NI-RFSG Playback Library no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-RFSG Playback Library 2023 Q2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 2023 Q2 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 2023 Q2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSG Playback Library (32-bit and 64-bit)
    LabVIEW2020 SP1, 2021, 2022 Q3, 2023 Q1
    Required Software
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed Software
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » National Instruments » NI-RFSG Playback Library Documentation.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library Examples.
    GMT+8, 2025-5-10 18:01
