查看: 912|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q2 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.3
    7 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-5-8 10:48:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q2
    发布日期:2023/4/20
    包含的版本:2023 Q2完整版,版本号23.3.0
    文件大小: 4572248064 字节 (4.26 GB)
    修改日期: 2023-04-21 21:50
    MD5: 465f62f9405c08bc0371d9aa5ce97238
    SHA1: 82ea9049526a0898f8420e03c6e95e9783319e2c
    SHA256: fe9fea529b25c5e57cef044eb929c3caef1f569c37c7dab44b0420c730368dc3
    CRC32: 39678f5b
    RFSG2023Q2.txt (514 Bytes, 下载次数: 0, 售价: 10 元)
    RFSG2023Q2未更新自述文件,参考2023Q1Patch版的自述说明:
    NI-RFSG 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q1 Patch.
    NI-RFSG 2023 Q1 Patch includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q1 Patch is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q1 Patch.
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    GMT+8, 2025-5-10 17:17
