查看: 820|回复: 0
[NI驱动程序] NI RF Signal Analyzers 2023 Q2 Win11 32/64bitEng NI PXI矢量信号分析仪驱动NI-RFSA 23.3.0
    9 小时前
  • 签到天数: 3533 天
    连续签到: 3 天
     楼主| 发表于 2023-5-8 10:41:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSA
    NI-RFSA 2023 Q2
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    语言:英文English
    文件大小: 4057143296 字节 (3.78 GB)
    修改日期: 2023-04-12 09:50
    MD5: d7ce2a2190c45a3882ab124e0f2bc9de
    SHA1: 3cdd9bf250dcf0674920c2aab80b3d1b999d494b
    SHA256: 83c1efce7cc4ad6b954035040716c6261e962068510e8d0384dead6482d4116e
    CRC32: 351106ed
    RFSA2023Q2.txt (514 Bytes, 下载次数: 0, 售价: 10 元)
    RFSA2023Q2版本未更新自述文件,参考2023Q1Patch版本的自述说明:
    NI-RFSA 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSA 2023 Q1 Patch.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Documentation: New features, behavior changes, and other documentation
    NI-RFSA 2023 Q1 Patch includes the following new feature:
    NI-RFSA 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSA 2022 Q4 includes the following new feature:
    NI-RFSA 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    NI-RFSA has the following requirements:
    • 4 GB RAM*
    NI-RFSA 2023 Q1 Patch and NI-RFSA SFP 2023 Q1 support the following operating systems:
    • NI Linux® Real-Time
    NI-RFSA supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSA. To add support for application software installed after installing NI-RFSA, modify your NI-RFSA installation or launch the NI-RFSA installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSA
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Note  Install any toolkits or add-on software you intend to use with the NI-RFSA instrument driver after NI-RFSA installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation.
    If you are using the NI-RFSA .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. For more information on .NET development using NI .NET drivers, visit ni.com/info and enter Info Code NETAPIdriversupport.
    To install the NI-RFSA .NET Class Library, ensure that you select .NET Framework 4.5 Languages Support or .NET Framework 4.0 Languages Support in the NI-RFSA installer.
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The "NI-RFSA Support for LabVIEW" package supports applications using NI-RFSA ​with LabVIEW 2023 Q1 or later. When installing NI-RFSA, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    Accessing the APILabVIEW
    NI-RFSA VIs are available in LabVIEW from the Functions»Measurement I/O»NI-RFSA palette.
    LabWindows/CVI
    .NET Framework
    You can use the NI-RFSA .NET Class library by adding a reference to NationalInstruments.ModularInstruments.NIRfsa.Fx40 or NationalInstruments.ModularInstruments.NIRfsa.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-RFSA. You can also select the Search tab to search all installed examples by keyword.
    You can access all the installed NI-RFSA examples at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Examples.
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI RF Vector Signal Analyzers HelpHTML/Windows HelpContains primary help content for NI-RFSA products. The help is an HTML version of a traditional user manual that includes the following information:
    • Hardware device overviews
    • The NI-RFSA Soft Front Panel Help
    • A complete reference for all NI-RFSA VIs, properties, and functions, as well as the NI-RFSA .NET Class Library Help
    Few other documentation for NI-RFSA is located at Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-5-8 09:35
