查看: 902|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2023 Q2 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试23.3
    8 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-5-6 17:27:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版/运行版,版本号23.3.0
    64位完整版校验和:
    文件大小: 1222410240 字节 (1.14 GB)
    修改日期: 2023-04-12 09:53
    MD5: bb06a0aaebd0ea50ae0a87618cddf2bf
    SHA1: 8152f1f4179826fb1bc895b240be504c2669dcb0
    SHA256: 8ae6e31f87a4a2b00eed5d98a0e4a11efd555a04936eed2be4525744c62a8f0d
    CRC32: 36280683
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx W-CDMA2023Q2.txt (542 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 672352256 字节 (641.21 MB)
    MD5: 5fed60021843745c006f8532884082c6
    SHA1: 4700f826eaba2845f882a9b2758322b48963b863
    SHA256: e012671af1805fd7a2a9ec8ecd1ade04d76de17eae176f3b47fc244f5aaebea8
    CRC32: fe09c4db
    RFmx W-CDMA2023Q2RTE.txt (575 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx WCDMA 2023 Q2 Readme
    April 2023
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx WCDMA 2023 Q2 includes the following new feature:
    RFmx WCDMA 2023 Q1 includes the following new feature:
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA 2023 Q2 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q2 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    Required Software
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    GMT+8, 2025-5-10 18:00
