查看: 911|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2023 Q2 Win11 64bitENG RFmx蜂窝测试TD-SCDMA23.3
    7 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-5-6 17:14:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版/运行版,版本号23.3.0
    64位完整版校验和:
    文件大小: 1219940352 字节 (1.14 GB)
    修改日期: 2023-04-12 09:53
    MD5: 45064cc3a256f784f99d718b52aca1de
    SHA1: 8a1a2211ecf584d9d9e756fb7b6a28d11bbbec1e
    SHA256: 1060e81e17a835b8e256f15adae1c2ac29f2e3268319a5d3826c8c521114fc71
    CRC32: 9fed0fd5
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2023Q2.txt (544 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 672491520 字节 (641.34 MB)
    MD5: 1425cc65cca3142d2082711f8f8ecac1
    SHA1: 4a641274705d56af7af5135dec29823eec98a1ca
    SHA256: 2adbe92419ebd3fdecb16d17371c7802fe487828efa2b12a2322942089a3d7c1
    CRC32: f2f70172
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2023Q2RTE.txt (577 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx TD-SCDMA 2023 Q2 Readme
    April 2023
    This file contains important information about the RFmx TD-SCDMA, including system requirements, and installation instructions.
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA has the following requirements:
    RFmx TD-SCDMA 2023 Q2 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q2 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    Required Software
    If you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx TD-SCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    The following is the behavior change in RFmx TD-SCDMA 20.7 from RFmx TD-SCDMA 20.6:
    GMT+8, 2025-5-10 17:25
