查看: 839|回复: 0
[NI软件产品] Power Validation Add-On 2023 Q2 for InstrumentStudio Win11 32/64bitEng InstrumentStudio电源验证附加工具23.0.1
    8 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-5-5 15:34:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    InstrumentStudio电子功率验证附加软件可帮助您采集、可视化和分析来自NI仪器的功耗和测量数据。
    InstrumentStudio电子功率验证附加工具是一个软件附加软件,其可用于使用PXI和CompactDAQ硬件执行基于分流电阻的功率测量。借助该附加软件,您可以自定义测量参数,从而优化采样率、精度、分辨率和通道数。您还可以配置和执行同步功率测量,而无需编程自定义测试。此外,InstrumentStudio电子功率验证附加软件提供了一个交互式面板,可帮助您查看和导出功率性能数据。
    发布日期:2023/4/28
    包含的版本:2023 Q2完整版,版本号23.0.1
    语言:英文English
    文件大小: 1384683520 字节 (1.29 GB)
    修改日期: 2023-04-29 09:53
    MD5: 7f674c9e6012e69d027d6fe55204b306
    SHA1: bac72dd5d52c4082b8649c759a5ee0506f81a0b0
    SHA256: ce6f7e053467d4dcd9165b547d3c910bdace1c236038afe81e9d7fdba8481d0d
    CRC32: e0a564b0
    请注册登录机器视觉论坛,购买附件后查看下载地址
    InstrumentStudio电源验证附加工具2023Q2.txt (602 Bytes, 下载次数: 0, 售价: 10 元)
    Power Validation Add-On For InstrumentStudio 2023 Q2 Readme
    April 2023
    This file contains installation instructions and compatibility information for Power Validation Add-On 2023 Q2 For InstrumentStudio.
    • Power Validation Add-On For InstrumentStudio Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Power Validation Add-On For InstrumentStudio Manuals: New features, behavior changes, and other documentation
    The Power Validation Add-On for InstrumentStudio is a plugin for interactively configuring and capturing measurements in InstrumentStudio.
    Power Validation Add-On for InstrumentStudio has the following requirements:
    • RAM—4 GB, 800 MHz DDR2 RAM
    Power Validation Add-On for InstrumentStudio supports the following operating systems:
    Power Validation Add-On for InstrumentStudio supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by Power Validation Add-On for InstrumentStudio 2023 Q2
    InstrumentStudio2023 Q1
    Download the Power Validation Add-On for InstrumentStudio installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Note If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    The following devices are supported:
    • NI-9220
    • PXIe-4309
    • PXIe-4139
    • NI-9252 (supported but not tested and might experience stability issues)
    • PXIe-6363 (supported but not tested and might experience stability issues)
    Refer to the Power Validation Add-On for InstrumentStudio Manual for information about the Power Validation Add-On for InstrumentStudio.
    The Power Validation Add-On for InstrumentStudio does not support Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    InstrumentStudio Environment Support
    After the installation of Power Validation Add-On for InstrumentStudio 2023 Q2 and/or InstrumentStudio 2023Q1, you can experience stability issue with old drivers versions .
    DriverVersions supported without any stability issues
    DAQmx2023 Q1
    NI-SCOPE2023 Q1.1
    © 2023 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-10 17:44
