查看: 1094|回复: 0
[LV工具模块] LabVIEW PDM Acquisition Toolkit 2022 Q4 x64Win10 32/64bitEng LV脉冲密度调制采集工具包22.8.0
    昨天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2023-5-5 10:42:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW PDM采集工具包
    LabVIEW PDM采集工具包可帮助您从数字麦克风中获取和转换脉冲密度调制(PDM)信号,以评估硬件性能。
    LabVIEW PDM采集工具包是LabVIEW的软件附加工具,可与PXIe-7820 PXI数字可重配置I/O设备结合使用。该附加工具提供了多种工具,可用于采集PDM信号,并将其转换为音频波形,以进行测试。您可以使用LabVIEW PDM采集工具包,采集多种不同速率和采样因子的PDM信号。
    发布日期:2023/2/10
    包含的版本:2022 Q4完整版专业版,版本号22.8.0
    语言:英文English
    文件大小: 2883190784 字节 (2.69 GB)
    修改日期: 2023-02-10 21:50
    MD5: 2e4460e2fa6451be9b479169b6f635aa
    SHA1: 8d7e5e8859b34e56c997c6595aecec7b92f5ecb5
    SHA256: c3d6f803c2d104911e6c4087be8cbd50aa99a0ce552a970defea89d7c74a6995
    CRC32: f52e839c
    请注册登录视觉论坛账号,购买附件查看下载地址
    PDM2022Q4.txt (616 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW PDM Acquisition Toolkit 2022 Q4 Readme
    February 2023
    This file contains installation instructions and compatibility information for LabVIEW PDM Acquisition Toolkit 2022 Q4.
    • LabVIEW PDM Acquisition Toolkit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW PDM Acquisition Toolkit Help: Basic concepts, API reference, specifications, and other information
    Driver and Add-On Requirements
    LabVIEW PDM Acquisition Toolkit 2022 Q4 supports only the Windows 10 (64-bit) operating system.
    LabVIEW PDM Acquisition Toolkit 2022 Q4 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by LabVIEW PDM Acquisition Toolkit 2022 Q4
    LabVIEW2018 SP1 Patch, 2019, 2020, and 2021
    If you are using the LabVIEW PDM Acquisition Toolkit .NET Class Library, .NET Framework 4.6.2 (minimum) is required. The LabVIEW PDM Acquisition Toolkit 2022 Q4 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.6.2 or later.
    LabVIEW PDM Acquisition Toolkit 2022 Q4 requires the following driver and add-on version: NI R Series Multifunction RIO 20.0.0.
    Download the LabVIEW PDM Acquisition Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    LabVIEW PDM Acquisition Toolkit 2022 Q4 includes the following new features:
    • Added support for 64-bit LabVIEW 2018 SP1 Patch, 2019, 2020, and 2021.
    • Provided C# APIs and examples.
    The following list details the hardware models supported in LabVIEW PDM Acquisition Toolkit 2022 Q4.
    • PXIe-7820/7821
    • USB-7845/7846
    Refer to the LabVIEW PDM Acquisition Toolkit Help, accessible at LabVIEW XXXX\help\pdmacquisition.chm or ni.com/r/pdmhelp, for information about the LabVIEW PDM Acquisition Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the LabVIEW PDM Acquisition Toolkit are located in the LabVIEW XXXX\examples\PDM Acquisition Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    C# dynamic-link library (DLL) and examples for the LabVIEW PDM Acquisition Toolkit are located in the following directories:
    • DLL: C:\Program Files\National Instruments\PDM Acquisition Toolkit\NationalInstruments.PDMToolkit.Task.dll
    • Examples: C:\Users\Public\Documents\National Instruments\PDM Acquisition Toolkit\Examples\DotNET
    GMT+8, 2025-6-1 12:02
