查看: 1012|回复: 0
[NI驱动程序] NI-Digital Pattern Driver 2023 Q2 Win11 32/64bitEng NI数字向量仪器驱动程序23.3下载
    7 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-5-5 10:25:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Digital Pattern Driver为用户使用NI PXI数字pattern仪器提供支持。
    NI-Digital Pattern Driver是用于配置和控制数字向量仪器的NI仪器驱动程序。该驱动程序可让您在NI-Digital Pattern Driver LabVIEW或.NET API中,调用使用数字向量编辑器创建的引脚和通道图、规格、电平、时序、向量、波形文件。NI-Digital Pattern Driver还包含高级和底层实用工具和示例,可帮助您轻松创建应用程序。
    从NI-Digital Pattern Driver 21.0版本开始,仅支持64位的Win10/WinServer 2016/WinServer 2019系统,但是仍然支持64位系统下的32位LabVIEW。自2022Q4V22.8版本开始,支持Win11操作系统。
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    语言:英文
    文件大小: 2369105920 字节 (2.21 GB)
    修改日期: 2023-04-12 09:51
    MD5: 0f680c4f8021655dc629dcb9faad88f5
    SHA1: 3fab505cd2b8d1b2f2ebb2534230365944feb03e
    SHA256: 21627936ae477c6f8ead6548ab1576943228829fc21d5a04d4adfc3d5525c9be
    CRC32: 83bfc2f6
    Digital Pattern Driver2023Q2.txt (541 Bytes, 下载次数: 0, 售价: 10 元)
    NI-Digital Pattern Driver 2023 Q2 Readme
    April 2023
    This file contains installation instructions and compatibility information for NI-Digital Pattern Driver 2023 Q2.
    • NI-Digital Pattern Driver Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Digital Pattern Driver Documentation: Detailed documentation about how to use your product
    Use the NI Digital Pattern Editor with a Digital Pattern Instrument and the NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs).
    NI-Digital Pattern Driver 2023 Q2 has the following requirements:
    Minimum System Requirements
    • 4 GB RAM
    • A screen resolution of 1024 x 768
    Recommended System
    • 8 GB RAM
    The NI-Digital Pattern Driver and the Digital Pattern Editor 2023 Q2 support the following operating systems with all available critical updates and service packs:
    NI-Digital Pattern Driver and Digital Pattern Editor 2023 Q2 support the following application software versions, including service packs.
    Versions Supported by NI-Digital Pattern Driver and Digital Pattern Editor 2023 Q2
    LabVIEW2020 and later
    NI TestStand2016 and later (64-bit)
    NI TestStand Semiconductor Module™2016 and later (64-bit)
    Microsoft Visual Studio2010 and later (.NET versions 4.0 and 4.5)
    Note: You must install the NI-DCPower driver to access NI-DCPower-related functionality in the Digital Pattern Editor.
    Note: You must install the NI-Sync driver to access NI-Sync-related functionality.
    If you are using the NI-Digital Pattern Driver .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-Digital Pattern Driver 2023 Q2 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Python Support
    For more information on installing and using the NI-Digital Python API, refer to the nidigital module.
    Download the NI-Digital Pattern Driver installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation method of the Suite or Bundle.
    Use the serial number that is included with your software to activate the NI-Digital Pattern Driver and Digital Pattern Editor. For more information on NI-Digital Pattern Driver and Digital Pattern Editor activation, refer to NI Software Activation.Accessing the APILabVIEW
    The NI–Digital Pattern Driver palette VIs are available from the following location:
    • Functions»Measurement I/O»NI–Digital palette or Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    .NET Class Library
    You can use the NI-Digital Pattern .NET class library by adding a reference to NationalInstruments.ModularInstruments.NIDigital.Fx40 or NationalInstruments.ModularInstruments.NIDigital.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the NI-Digital Pattern C dynamically linked library by adding a reference to C:\Program Files\IVI Foundation\IVI\Bin\niDigital_64.dll for 64-bit development.
    The "NI-Digital Pattern Driver Support for LabVIEW" package supports applications using NI-Digital Pattern Driver ​with LabVIEW 2022 or later [1]. When you install NI-Digital Pattern Driver on LabVIEW 2022 or later, this package is recommended and will install to the LVAddons directory.
    Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Software Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version.
    Refer to the NI-Digital Pattern Driver documentation, accessible from Help»LabVIEW Help..., for information about the NI-Digital Pattern Driver. The installed documentation set is composed of the following document:
    • Digital Pattern Help—Contains information about using the Digital Pattern Editor with a Digital Pattern Instrument and NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs). Includes references for the NI-Digital Pattern Driver VIs and properties, the NI-Digital Pattern Driver C functions, and the NI-Digital Pattern .NET Class Library.
    Digital Pattern Instrument manuals are available as PDFs. You must have Adobe Acrobat Reader installed to view the PDFs. You can install the viewer from www.adobe.com/acrobat.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/docs. Digital Pattern Instrument manuals include the following documents:
    • PXIe-6570 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6570.
    • PXIe-6570 Specifications—Lists technical specifications for the PXIe-6570.
    • PXIe-6570 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6570.
    • PXIe-6571 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6571.
    • PXIe-6571 Specifications—Lists technical specifications for the PXIe-6571.
    • PXIe-6571 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6571.
    Use the getting started examples, located by default in the \National Instruments\NI-Digital\Examples\Getting Started directory, to help you learn key concepts or to serve as a starting point for applications you create. You can also access the getting started examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
    In the Welcome window of the Digital Pattern Editor, click Examples or click the Learning tab to launch the Learning window, which includes examples of common usages of digital patterns.
    NI-Digital Pattern Driver Examples
    Use the NI-Digital Pattern Driver example programs to learn more about how to use the NI-Digital Pattern Driver software to configure and control digital pattern instruments.
    LabVIEW Examples
    Use the NI Example Finder to locate LabVIEW examples. In LabVIEW, select Help»Find Examples to launch the NI Example Finder.
    Microsoft .NET Examples
    The Microsoft .NET examples are located in the \National Instruments\NI-Digital\Examples\DotNET 4.x directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    C Examples
    The C examples are located in the \National Instruments\NI-Digital\Examples\C directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    NI-Digital Pattern Driver no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-5-10 17:15
