查看: 1710|回复: 0
[NI软件产品] NI RFIC Test Software 22.5.0 x64Win10 64bitEng NI-RFIC测试软件22.5.0
     楼主| 发表于 2023-3-27 12:23:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFIC测试软件
    RFIC测试软件简化了宽带RF IC的特性分析。
    RFIC测试软件是一款应用软件,可帮助您分析功率放大器(PA)和前端模块(FEM)等RFIC的特性。如果要对PA进行线性化,有多种针对特定应用的数字预失真(DPD)算法可供选择,例如查找表(LUT)、记忆多项式(MP)和广义记忆多项式(GMP)。此外,您还可以集成并运行NI联盟伙伴的线性化算法或技术。当使用像PXI矢量信号收发仪这样的NI仪器时,您还可以使用该软件来分析包络跟踪(ET)等功率效率优化技术。您可以使用GUI来保存手动配置和执行,以便重复使用这些配置和执行或与其他测试平台共享。National Instruments Alliance Partner(NI联盟伙伴)是独立于NI的商业实体,与NI之间不存在代理、合伙或合资关系。
    发布日期:2023/3/3
    包含的版本:22.5.0完整版
    受支持的操作系统:Windows 10 64-bit
    语言:英文
    文件大小: 718815232 字节 (685.52 MB)
    修改日期: 2023-03-02 09:49
    MD5: afebd745740cca9d7aeeb1be8b0cd1c7
    SHA1: ff0dc40d24ae3ad8568b25b7d4768ea8908424d1
    SHA256: 0a9e11b2c4c4d74d444ce3ee72e1c99cbc6608a81d854212dd5cd5517082065f
    CRC32: 401031f7
    RFICts22.5.txt (588 Bytes, 下载次数: 0, 售价: 10 圆)
    RFIC Test Software 22.5 Readme
    March 2023
    This file contains installation instructions and compatibility information for RFIC Test Software 22.5.
    • RFIC Test Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFIC Test Software Documentation: New features, behavior changes, and other documentation
    Driver and Add-On Requirements
    Accessing the APIs
    RFIC Test Software 22.5 has the following minimum requirements:
    • Processor—Intel Pentium 4 or equivalent
    • 1 GB RAM*
    • A screen resolution of 1,024 x 768 with 256 colors
    NI recommends the following requirements:
    • 4 GB RAM*
    • A screen resolution of 1,600 x 1,200
    * Depending on the amount of data acquired and/or processed a larger amount of memory may be required.
    RFIC Test Software 22.5 supports Windows 10 (64-bit).
    RFIC Test Software 22.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Note  Install application software, such as LabVIEW or Microsoft Visual Studio, before installing RFIC Test Software. To add support for application software installed after installing RFIC Test Software, modify your RFIC Test Software installation or launch the RFIC Test Software installer again.
    Versions Supported by RFIC Test Software 22.5
    LabVIEW (64-bit)2020 SP1, 2021 SP1 f1 patch, 2022 Q3, and 2023 Q1
    Microsoft Visual Studio2017(minimum)
    TestStand2021
    Note  RFIC Test Software cannot operate correctly without the service packs previously mentioned.
    If you are using the RFIC Test Software .NET Class Library, .NET Framework 4.6.2 (minimum) is required. The RFIC Test Software 22.5 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.6.2.
    RFIC Test Software requires the following driver and add-on versions:
    • NI-RFSG 2023 Q1
    • NI-RFSA 2023 Q1
    • NI-FGEN 2023 Q1
    • NI-DCPower 2023 Q1
    • NI-SCOPE 2023 Q1
    • RFmx SpecAn 2023 Q1
    • RFmx Analog Modulation 2023 Q1
    • RFmx LTE 2023 Q11
    • RFmx NR 2023 Q11
    • RFmx WLAN 2023 Q11
    • NI-RFSG Playback Library 2023 Q1
    • (Optional) NI-SWITCH 2023 Q12
    • (Optional) NI-Digital Pattern Driver 21.83
    • (Optional) Semiconductor Device Control Add-On 2022 Q3 Base for InstrumentStudio3
    • (Optional) Single-Band RF Power Amplifier Linearizer 1.7 or later⁴
    • (Optional) Dual-Band RF Power Amplifier Linearizer 2.1 or later⁴
    • (Optional) NI-DMM 2023 Q1⁵
    • (Optional) NI-568x Driver Software 20.0⁶
    1 Installation and licensing are only required for standard-specific measurements.
    2 Required to use the PXI-2599 RF Relay Module to connect the PXIe-5830/5831 and the PXIe-5840/5841 Vector Signal Transceivers.
    3 Required to control DUTs that use the MIPI® RF front-end (RFFE) or SPI hardware protocol.
    ⁴ Requires a valid license.
    ⁵ Required to measure system power-added efficiency (PAE) with PXIe-4080/4081 Digital Multimeters.
    ⁶ Required to measure RF power level with USB-5681/5683/5684 RF Power Sensor Devices.
    Note  The run-time versions of these products are sufficient to run the RFIC Test SFP.
    Refer to the readme of each driver and add-on for more information about system requirements, installation instructions, and activation.
    Download the RFIC Test Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    After installing your software, you will need to activate it. Activating your software verifies the licenses associated with your NI account, so you can start using your software. You have different options for activation, based on your software and how it was purchased. Visit ni.com/activate for more information on activation methods.
    Activation Notice
    The following table lists the measurements and features included in the RFIC Test Software Base and Professional versions. You must have a valid license to activate RFIC Test Software Professional. For more information about activation, refer to NI Software Activation.
    Measurement and Feature
    General measurements
    Software-based power servo
    Excludes power meter-based servo
    Hardware-accelerated power servo
    Transmission power (TXP)
    Adjacent channel power (ACP)
    Modulation accuracy (ModAcc - including EVM)
    Spectral emission mask (SEM)
    AM-to-AM (AMAM) and AM-to-PM (AMPM)
    Digital predistortion (DPD)
    Load pull
    Single point only, excludes sweeping
    PAE
    Dynamic EVM (DEVM)
    Envelope tracking (ET)
    Crest factor reduction (pre-DPD and post-DPD)
    Swept measurements (power, frequency, and load pull)
    Power sweeping only
    Complementary cumulative distribution function (CCDF)
    Routing triggers
    Cross-correlation EVM optimization
    RFIC Test Software 22.5 supports the following new features:
    • Support for RMM-5585
    • Support for saving and loading MP and GMP DPD coefficients
    • Support for RFmx WLAN OFDMModAcc Channel Estimation Interpolation Type
    • Support for using the signal generator (SG) waveform as the Modulation Accuracy (ModAcc) reference waveform for WLAN OFDM EVM calculation
    • Support for Cross-Correlation EVM for WLAN and NR on PXIe-5842
    • Adoption of Noise Reconstitution IP to WLAN and NR Cross-Correlation EVM measurements
    The following table details the hardware models supported in RFIC Test Software 22.5.
    Hardware Product
    Hardware Model
    Vector Signal TransceiverPXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5840
    PXIe-5841
    PXIe-5842
    Waveform GeneratorPXIe-5451
    OscilloscopePXIe-5162
    Source Measure UnitPXIe-4145
    RF Power Sensor DeviceUSB-5681
    USB-5683
    USB-5684
    R&S® NRP50S
    RF Relay ModulePXI-2599
    Digital Pattern InstrumentPXIe-6571
    Digital MultimeterPXIe-4080
    PXIe-4081
    Remote Measurement ModuleRMM-5585
    mmWave Radio HeadmmRH-5582
    Note Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version.
    Accessing the APIsLabVIEW
    ETSync VIs are available in LabVIEW from the Functions»Addons»ET palette.
    Power Servo VIs are available in LabVIEW from the Functions»User Libraries»NI Power Servoing IP palette.
    NanoSemi Linearizer VIs and NanoSemi Dual Band VIs are available in LabVIEW from the Functions»User Libraries»NanoSemi Linearizer and NanoSemi Dual Band palettes, respectively.
    .NET Framework
    You can use the ETSync .NET Class library by adding a reference to niETSync.cs, niETUtil.cs, and niFGEN.cs from C:\Users\Public\Public Documents\National Instruments\NI-ETSync\DotNET Wrappers\CS\ and any dependent class libraries from within the Solution Explorer in Visual Studio.
    You can use the Power Servo .NET Class library by adding a reference to niVSTPowerServo.cs, niRFSA.cs, and niInteropCommon.cs from C:\Users\Public\Public Documents\National Instruments\FPGA Power Servo\DotNET Wrappers\CS\ and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the ETSync C dynamically linked library by adding a reference to: Program Files\IVI Foundation\IVI\Bin\niETSync_64.dll.
    You can use the Power Servo C dynamically linked library by adding a reference to: Program Files\IVI Foundation\IVI\Bin\niVSTPowerServo_64.dll.
    RFIC Test SFP
    To launch the RFIC Test SFP, select Start»National Instruments»RFIC Test Soft Front Panel.
    Refer to the RFIC Test Software User Manual (rfichelp.chm), located at Start»National Instruments»RFIC Documentation.
    For information about your device, such as getting started, technical specifications, and calibration instructions, refer to the documentation for your device. For the most recent revisions of documentation and newly released documentation, visit ni.com/docs.
    LabVIEW, .NET, and TestStand examples are available through the RFIC Test Automation Wizard, accessible from Start»National Instruments»RFIC Test Automation Wizard.
    RFIC Test Software no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-13 11:32
