查看: 1071|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2023 Q1 Win11 32/64bitEng NI-RFSG回放库23.0
    7 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-3-22 17:31:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版,版本号23.0.0
    32/64位完整版校验和:
    文件大小: 417804288 字节 (398.45 MB)
    修改日期: 2023-02-04 09:52
    MD5: 35a5711e6a86df06bb54ddabeec18ce7
    SHA1: 6ec9aa5817fa0dcf351139a097497ba0a4a8b38f
    SHA256: ab3c38d49b6372346f11537484ad6d2c1104c11806497b97292b1e969c31e3d9
    CRC32: 8cdf767d
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFSG回放库2023Q1.txt (592 Bytes, 下载次数: 0, 售价: 10 元)
    32/64位运行版校验和:
    文件大小: 265224192 字节 (252.94 MB)
    MD5: f41125a34c250f54a2403957e4c2dbc0
    SHA1: 7912a95be4eb374bfe04292c8eea1b494e5dd394
    SHA256: be910464033505675ab7adda7af8b1823ae1d39172b6fb0163b5aed14fcd069d
    CRC32: b1a04992
    RFSG回放库2023Q1RTE.txt (619 Bytes, 下载次数: 0, 售价: 5 元)
    NI-RFSG Playback Library 2023 Q1 Readme
    January 2023
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    • NI-RFSG Playback Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Playback Library Manuals: New features, behavior changes, and other documentation
    Installed Software
    NI-RFSG Playback Library 2023 Q1 includes the following new features:
    • Support for LabVIEW 2023 Q1 (32-bit and 64-bit)
    NI-RFSG Playback Library 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    NI-RFSG Playback Library 2022 Q3 includes the following new features:
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 2023 Q1 supports the following 64-bit operating systems:
    Note    NI-RFSG Playback Library no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-RFSG Playback Library 2023 Q1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 2023 Q1 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 2023 Q1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSG Playback Library
    LabVIEW2020 SP1, 2021, 2022 Q3, 2023 Q1
    Required Software
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed Software
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » National Instruments » NI-RFSG Playback Library Documentation.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library Examples.
    GMT+8, 2025-5-10 17:28
