查看: 1298|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q1 Patch 1 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.0.1
    8 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-3-22 17:18:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q1 Patch 1
    发布日期:2023/3/9
    包含的版本:2023 Q1 Patch 1完整版,版本号23.0.1
    文件大小: 4454072320 字节 (4.15 GB)
    修改日期: 2023-03-09 21:52
    MD5: 93add818b5721e69a20a18c78fa524cd
    SHA1: 59b159d8c59bf2a27518c7535097e07571f9fa79
    SHA256: 9a600396c29b7d0cf9786808b688aaed5846026a0d0db5660acac675f29938a5
    CRC32: 2e0bf69f
    RFSG2023Q1 Patch1.txt (526 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSG 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q1 Patch.
    NI-RFSG 2023 Q1 Patch includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q1 Patch is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q1 Patch.
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    GMT+8, 2025-5-10 18:20
