查看: 1418|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q1 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.0.0
    7 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-3-22 17:14:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q1
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版,版本号23.0.0
    文件大小: 4623892480 字节 (4.31 GB)
    修改日期: 2022-10-13 09:53
    (MD5) 85cc520908e564cd34ddfe3b96a34051
    (SHA256) f44973acb4ad4459b8011eff555578f85811d3a03ab16949dd72393e9f232ff8
    RFSG2023Q1.txt (518 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSG 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q1.
    • Support for LabVIEW 2023 Q1
    • Support for PXIe-5842
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q1 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q1.
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    GMT+8, 2025-5-10 17:27
