查看: 1187|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2023 Q1 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试23.0
    昨天 10:30
  • 签到天数: 3567 天
    连续签到: 12 天
     楼主| 发表于 2023-3-22 12:13:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版/运行版,版本号23.0.0
    64位完整版校验和:
    文件大小: 1002768384 字节 (956.31 MB)
    修改日期: 2023-02-04 09:52
    MD5: ff4388c8c2347b88effe1b817fa32b64
    SHA1: e0d00e1711558fab0c05851e9aa9aab2f369e2ea
    SHA256: 107d95597cc18833c6d9ed4503eaf926766e72baf0bd8e63583eea5f84be9cbb
    CRC32: 201ac132
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx W-CDMA2023Q1.txt (553 Bytes, 下载次数: 0, 售价: 10 元)
    64位运行版校验和:
    文件大小: 489580544 字节 (466.90 MB)
    MD5: 77cbcc156491c4b4298d85385e17da55
    SHA1: fb6c948bb8fadde68a7b09589ff0981fffcb561e
    SHA256: d0779a96c94c15f327458fe99103658176cfb3ffb0bfdd06c1e58e74c09e9777
    CRC32: 9b2a6c17
    RFmx W-CDMA2023Q1RTE.txt (579 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx WCDMA 2023 Q1 Readme
    January 2023
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx WCDMA 2023 Q1 includes the following new feature:
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA 2022 Q3 includes the following new feature:
    RFmx WCDMA 2023 Q1 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q1 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    Required Software
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    举报
    GMT+8, 2025-6-15 08:14
