查看: 1135|回复: 0
[NI驱动程序] NI-Industrial Communications for EtherCAT 2023 Q1 Win11 32bitEng 以太网控制自动化技术工业通信软件23.0
    12 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2023-3-21 18:16:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Industrial Communications for EtherCAT提供了EtherCAT主站支持,以支持NI控制器硬件上的确定性I/O。
    NI-Industrial Communications for EtherCAT为用户使用CompactRIO控制器、PXI控制器或工业控制器提供支持。使用此软件,您可以通过使用基于EtherCAT总线的CompactRIO机箱或使用远程I/O硬件来扩展I/O。NI建议结合经过充分测试和验证的NI EtherCAT产品使用此驱动软件。
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版,版本号23.0.0
    支持的操作系统:
    语言:英文English
    应用程序位数:32位
    文件大小: 948692992 字节 (904.74 MB)
    修改日期: 2023-02-04 09:50
    MD5: 091549cc2ed1973974c8100bd17f3f04
    SHA1: 3dee308df4484a69c8263213ea39eb45523ac81f
    SHA256: a91fbdb40ba0766e480aa94c5b7fc3f258d1647666aceba7d121f5ef53c4a536
    CRC32: 0e28b929
    Industrial Communications for EtherCAT2023Q1.txt (565 Bytes, 下载次数: 0, 售价: 10 元)
    NI-Industrial Communications for EtherCAT® 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for NI-Industrial Communications for EtherCAT 2023 Q1.
    • NI-Industrial Communications for EtherCAT Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Industrial Communications for EtherCAT Documentation: New features, behavior changes, and other documentation
    Supported EtherCAT Masters
    The NI-Industrial Communications for EtherCAT software provides an EtherCAT master driver to support the real-time EtherCAT network operations. Use the software with the LabVIEW Real-Time Module to configure the EtherCAT network and map the EtherCAT device signals to the LabVIEW I/O variables.
    NI-Industrial Communications for EtherCAT 2023 Q1 supports the following operating systems:
    Software Requirements
    To install the NI-Industrial Communications for EtherCAT software, install the following prerequisite software.
    • LabVIEW 2020 SP1 or later
    • LabVIEW 2020 SP1 Real-Time Module or later
    • NI CompactRIO Device Drivers October 2021
    • NI 9145 is the only EtherCAT slave that has FPGA support in LabVIEW. To use the NI 9145 in FPGA Mode, install the LabVIEW 2014 FPGA Module or later on the host computer and then download a bitfile to the FPGA of the NI 9145. You can compile or copy a bitfile to download to the FPGA.
    • NI 951x Series drive interface modules require the LabVIEW 2014 SoftMotion Module or later to work for EtherCAT.
    Download the NI-Industrial Communications for EtherCAT installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "NI-Industrial Communications for EtherCAT LabVIEW Support" and "NI-Industrial Communications for EtherCAT Support for LabVIEW FPGA Module" packages support applications using NI-Industrial Communications for EtherCAT ​with LabVIEW 2023 or later. When installing NI-Industrial Communications for EtherCAT, these packages will be recommended if you have already installed LabVIEW 2023 or later and installed to the LVAddons directory.
    • Added support for LabVIEW 2022 Q3 and LabVIEW 2023 Q1 versions
    The following table lists the supported EtherCAT masters and the earliest supported version of the NI-Industrial Communications for EtherCAT.
    EtherCAT Master
    Earliest Supported Version
    PXI-81061.0
    PXIe-81301.0
    PXI-81041.0
    PXI-81081.01
    All real-time embedded PXI controllers with the PXI-8231 or PXI-8232 Ethernet interface2.0
    PXIe-81332.0
    PCI-82322.0
    PCIe-82312.0
    PCIe-82332.0
    PCIe-82352.0
    cRIO-90812.2
    cRIO-90822.2
    RMC-8354RT2.5
    RMC-8355RT2.5
    PXI-81092.5
    PXI-81152.5
    PXIe-81152.5
    PXIe-81352.5
    cRIO-90682.6
    cRIO-903014.0
    cRIO-903114.0
    cRIO-903314.0
    cRIO-906714.0
    sbRIO-965114.0
    cDAQ-9132RT14.0
    cDAQ-9134RT14.0
    PXI-884014.0
    PXIe-884014.0
    PXI-811914.0
    PXIe-811914.0
    PXIe-888014.0
    PXIe-888121.5
    cRIO-903414.5
    cRIO-903514.5
    cRIO-903614.5
    cRIO-903814.5
    cRIO-903914.5
    cRIO-906414.5
    cRIO-906514.5
    cDAQ-9133RT14.5
    cDAQ-9135RT14.5
    sbRIO-960715.0
    sbRIO-962715.0
    cDAQ-9136RT15.0
    cDAQ-9137RT15.0
    CVS-1458RT15.0
    cRIO-903216.0
    cRIO-903716.0
    cRIO-9035 (Sync)16.0
    cRIO-9039 (Sync)16.0
    IC-317116.0
    IC-317216.0
    IC-317316.0
    cRIO-904x17.6
    cRIO-905x18.0
    PXIe-8840 Quad-Core with NI Linux Real-Time18.5
    PXIe-8880 with NI Linux Real-Time18.5
    PXIe-8861 with NI Linux Real-Time19.0
    All PXIe controllers with NI Linux Real-Time with the PXIe-8245 or PXIe-8246 Ethernet interfaces21.3
    sbRIO-960320.0
    sbRIO-960820.0
    sbRIO-960920.0
    sbRIO-962820.0
    sbRIO-962920.0
    sbRIO-963820.0
    Note  NI does not recommend using cDAQ real-time controllers with the NI 9145 EtherCAT slave device in FPGA mode, because cDAQ real-time controllers cannot read user-defined variables from the NI 9145 EtherCAT slave device. When using a cDAQ real-time controller as the master device, you can only read EtherCAT device signals from the LabVIEW I/O Variable Functions. You cannot read directly from the LabVIEW I/O variables.
    Note  If you use NI Measurement & Automation Explorer (MAX) to install the NI-Industrial Communications for EtherCAT software on real-time controllers, some controllers, such as the Embedded Vision System, require you to install the controller driver software. Otherwise, MAX cannot discover the controllers.
    Note  In NI-Industrial Communications for EtherCAT 18.5, PXIe-8840 Quad-Core with NI Linux Real-Time and PXIe-8880 with NI Linux Real-Time are supported only for VeriStand. In NI-Industrial Communications for EtherCAT 19.0 or later, this support no longer relies on VeriStand.
    Note  NI-Industrial Communications for EtherCAT 21.5 or later supports only the non-primary built-in Ethernet port of PXI controllers with NI Linux Real-Time.
    Refer to the NI-Industrial Communications for EtherCAT® Help, available by selecting Help»NI-Industrial Communications for EtherCAT from LabVIEW, for information about the NI-Industrial Communications for EtherCAT software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherCAT folder to access the examples.
    If you are using LabVIEW 2023, you can find the examples for NI-Industrial Communications for EtherCAT® in the niecat\1\examples\indcomecat folder under LVAddons directory.
    If you are using LabVIEW 2022 or earlier, you can find the examples for NI-Industrial Communications for EtherCAT® in the labview\examples\indcomecat folder.
    NI-Industrial Communications for EtherCAT no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    Credits
    This product includes components that use the Expat XML Parser. In regards to the Expat XML Parser, the following notice applies:
    Copyright © 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper. Copyright © 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    GMT+8, 2025-5-10 21:52
