查看: 1937|回复: 0
[NI软件产品] NI VeriStand 2023 Q1 and Drivers Win11 64bitEng VerStand PC版完整版及运行版2023Q1 NIVS23.0.0含驱动版8.9GB
    6 小时前
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2023-3-20 12:20:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI VeriStand 2023 Q1和驱动程序
    发布日期:2023/2/3
    包含的版本:2023 Q1PC版、完整版、运行版,版本号23.0.0
    文件大小: 9555816448 字节 (8.90 GB)
    修改日期: 2023-02-04 09:50
    MD5: 18e8efbb136eb188d52f6eea4d3374a0
    SHA1: 9726da07a07ad62cd72ae66eccbe8427be2f22de
    SHA256: c04f5f17a84e9ece1716e5091d187b65a5f0c88d36ef143cc9a82b8a447a7182
    CRC32: 8ccdbd8a
    请注册登录视觉论坛账号,购买附件查看下载地址
    VeriStand2023Q1和驱动程序.txt (586 Bytes, 下载次数: 3, 售价: 20 圆)
    VeriStand 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for VeriStand 2023 Q1.
    • VeriStand Documentation: New features, behavior changes, and other documentation
    VeriStand 2023 Q1 installs with the following:
    • NI-DAQmx 2023 Q1
    • NI-VISA 2022 Q4
    • NI-SLSC 2023 Q1
    • NI-XNET 2023 Q1
    • NI R Series Multifunction RIO 2023 Q1
    Simulation Models
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    VeriStand 2023 Q1 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 11 64-bit version 21H2
    • Windows 10 64-bit version 21H21
    When formatting a disk with a PXI Linux RT system image for VeriStand 2023 Q1, select Linux RT System Image 2023 Q1 and enable support for the LabVIEW 2023 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2023 Q1.
    Note  NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2023 Q1. To access the documents, refer to the VeriStand Release Notes.
    Uncompiled Models
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions.
    Note  Models built with LabVIEW 2023 Q1 and later no longer support simulation subsystems developed using the LabVIEW Control Design and Simulation Module add-on.
    Migrating Files from VeriStand 2010 to 2018 SP1
    VeriStand 2023 Q1 can open projects from VeriStand 2010 to 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    LabVIEW can no longer automate actions with legacy stimulus profiles. Consider migrating to modern stimulus profiles and real-time sequences.
    In addition, the following LabVIEW automation VIs are deprecated and no longer included with VeriStand:
    • NI VeriStand - Get Alarm Status.vi
    • NI VeriStand - Get Engine State.vi
    • NI VeriStand - Lock Workspace File.vi
    • NI VeriStand - Run Workspace File.vi
    • NI VeriStand - Stop Workspace File.vi
    • NI VeriStand - Unlock Workspace File.vi
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q1 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q1 .NET API Help.
    • VeriStand Project — An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\VeriStand 2023\Projects\Example directory.
    • Stimulus Profile Editor — VeriStand Stimulus Profile Editor examples are located in the \National Instruments\VeriStand 2023\Examples directory.
    • ASAM XIL and Custom Device Sample Configurations — Configuration examples for ASAM XIL and custom devices are located in the \National Instruments\VeriStand 2023\Examples directory.
    • LabVIEW API — LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2023\examples\NI VeriStand directory or in the \National Instruments\LabVIEW 2023\examples\NI VeriStand Custom Devices directory.
    GMT+8, 2026-2-2 16:40
