HIL and Real-Time Test Software Suite 2023 Q1 Win11 32bitEng 硬件在环和实时测试软件套件2023Q1版-32位英文
HIL and Real-Time Test Software Suite是用于验证嵌入式软件和运行模型物理测试的软件集合。
HIL and Real-Time Test Software Suite将LabVIEW集成开发环境(IDE)与应用软件和模块相结合,用于创建实时测试应用程序。借助该套件,您可以开发仿真模型和控制算法,并将其部署到实时硬件中。您还可以添加自定义功能,确保测试系统具有足够的灵活性来满足几乎任何应用需求,此外,您还可以在NI可重配置I/O硬件上执行高速仿真和处理。
套件包含:
LabVIEW专业版开发系统
LabVIEW高级信号处理工具包
VeriStand完整版开发系统
LabVIEW Real-Time模块
LabVIEW FPGA模块
LabVIEW控制设计与仿真模块
LabVIEW状态图模块
相关NI设备驱动程序
发布日期:2023/2/7
包含版本:2023 Q1专业版,版本号23.0.0
应用程序位数:32位
语言:英文English
文件大小: 33498873856 字节 (31.20 GB)
修改日期: 2023-02-17 12:55
MD5: 875ada747ca6565d7f420ef7321eff75
SHA1: 125bbb52e8240b0243811c7e69c0dfbb4d8cf3b8
SHA256: 6bdb2388118feb027ead00eba6f9878638c63e381bbb2ad565d77cbd6a514631
CRC32: f30b8319
请注册登陆机器视觉论坛账号,购买附件查看下载地址
HIL RT测试软件套件2023Q1x86Eng.txt
(668 Bytes, 下载次数: 0, 售价: 40 圆)
HIL and Real-Time Test Software Suite 2023 Q1 ReadmeJanuary 2023 This file contains installation instructions and compatibility information for HIL and Real-Time Test Software Suite 2023 Q1. You can find more release information on ni.com. - HIL and Real-Time Test Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
System Requirements Supported Operating Systems Products Included in the HIL and Real-Time Test Software Suite Installation Instructions Product Security and Critical Updates Supported Hardware Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Unsupported Windows Operating Systems NI no longer supports Phar Lap ETS Real-Time Operating System System RequirementsRefer to the readme of each product for system requirements. Supported Operating SystemsHIL and Real-Time Test Software Suite 2023 Q1 supports the following operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Products Included in the HIL and Real-Time Test Software SuiteThe following products are included in the HIL and Real-Time Test Software Suite installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes. Application SoftwareProduct | Version | Bitness | LabVIEW | 2023 Q1 | 32-bit and 64-bit | VeriStand | 2023 | 64-bit |
This product no longer supports LabVIEW NXG. Refer to LabVIEW NXG on ni.com for more information about LabVIEW NXG Life-Cycle Dates and driver version support. Add-onsProduct | Version | Bitness | JKI VI Package Manager | 2023 Q1 | 32-bit and 64-bit | LabVIEW FPGA Compilation Tool for Vivado 2021.1 | 2022 Q3 | 64-bit | LabVIEW FPGA Compile Farm Toolkit | 2023 Q1 | 32-bit and 64-bit | LabVIEW FPGA Module | 2023 Q1 | 32-bit and 64-bit | LabVIEW Real-Time Module | 2023 Q1 | 32-bit and 64-bit | VeriStand Model Framework | 2021 | 32-bit and 64-bit | VeriStand Model Generation Support for LabVIEW 2023 Q1 | 2023 Q1 | 32-bit and 64-bit |
Note: The LabVIEW Professional Development System installs the LabVIEW Advanced Signal Processing Toolkit, LabVIEW Desktop Execution Trace Toolkit, LabVIEW Digital Filter Design Toolkit, LabVIEW Unit Test Framework Toolkit, LabVIEW VI Analyzer Toolkit, LabVIEW Database Connectivity Toolkit, and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory. DriversProduct | Version | Bitness | FlexRIO with Integrated I/O | 2023 Q1 | 32-bit and 64-bit | FlexRIO with Modular I/O | 2023 Q1 | 32-bit and 64-bit | NI CompactRIO | 2023 Q1 | 32-bit and 64-bit | NI-488.2 | 2022 Q4 | 32-bit and 64-bit | NI-DAQmx | 2023 Q1 | 32-bit and 64-bit | NI-DCPower | 2023 Q1 | 32-bit and 64-bit | NI-Industrial Communications for EtherCAT | 2023 Q1 | 32-bit and 64-bit | NI-SWITCH | 2023 Q1 | 32-bit and 64-bit | NI-Sync | 2023 Q1 | 32-bit and 64-bit | NI-VISA | 2022 Q3 | 32-bit and 64-bit | NI-XNET | 2023 Q1 | 32-bit and 64-bit | PXI Platform Services | 2023 Q1 | 32-bit and 64-bit | R-Series | 2023 Q1 | 32-bit and 64-bit |
Note: Some drivers included with previous versions of HIL and Real-Time Test Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions. Microsoft Visual Studio SupportIf you are using the HIL and Real-Time Test Software Suite .NET Class Library, .NET Framework 4.0 (minimum) is required. The HIL and Real-Time Test Software Suite 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software. Installation InstructionsDownload the HIL and Real-Time Test Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate HIL and Real-Time Test Software Suite 2023 Q1. For more information on HIL and Real-Time Test Software Suite 2023 Q1 activation, refer to Activating a Product.
Complete the following steps to install products using the HIL and Real-Time Test Software Suite media. - Insert the HIL and Real-Time Test Software Suite installation media.
- Follow the installer prompts, enter any required information, and activate when prompted, if necessary.
Save the original installation media in order to modify or repair your installation or to distribute NI software with your custom-built installers. Installing LabVIEW Add-OnsInstalling LabVIEW add-ons, such as modules and toolkits, from the HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. Finding ExamplesRefer to the readme of each product for examples. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Unsupported Windows Operating SystemsHIL and Real-Time Test Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. NI No Longer Supports Phar Lap ETS Real-Time Operating SystemNI Software no longer supports Phar Lap ETS Real-Time Operating System. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi. |
