查看: 1464|回复: 0
[NI软件套件] NI Test Workflow 2023 Q1 Pro Win11 64bitEng NI测试工作流程23.0专业版-64位英文
  • 签到天数: 3559 天
    连续签到: 4 天
     楼主| 发表于 2023-3-17 09:16:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Test Workflow测试工作流程
    专业版包含:
    应用程序软件
    LabVIEW专业版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem专业版
    TestStand
    附加软件
    LabVIEW VI Analyzer工具包
    发布日期:2023/2/7
    包含的版本:2023 Q1专业版,版本号23.0.0
    语言:英文English
    文件大小: 9530734592 字节 (8.88 GB)
    修改日期: 2023-02-08 09:53
    MD5: 69a28d5c0ea0ade98bb42fe276703721
    SHA1: 588d78f470d6b71edc972a7f287eeda8599019df
    SHA256: 709dc351feb21c3aac3de9090fadaa8c00cf994327708d8877ad0f7095da8316
    CRC32: fd32f9e3
    注册登录视觉论坛,购买附件查看下载地址
    TestWorkflow2023Q1Prox64Eng.txt (603 Bytes, 下载次数: 0, 售价: 30 元)
    Test Workflow 2023 Q1 Pro Readme
    January 2023
    This file contains installation instructions and compatibility information for Test Workflow 2023 Q1 Pro.
    • Test Workflow Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Test Workflow Pro Bundle
    Test Workflow 2023 Q1 Pro supports the following operating systems:
    The following products are included in the Test Workflow Pro installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    DIAdem2022 Q464-bit
    FlexLogger2023 Q1164-bit
    InstrumentStudio2023 Q164-bit
    1FlexLogger 2023 Q1 does not support 2023 Q1 NI driver software.
    If you are using the Test Workflow .NET Class Library, .NET Framework 4.0 (minimum) is required. The Test Workflow 2023 Q1 Pro .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Test Workflow installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow. For more information on Test Workflow activation, refer to Activating a Product.
    Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-6-6 19:08
