查看: 1212|回复: 0
[LV工具模块] LabVIEW 2023 Q1 Real-Time Module Win11 32bitEng LabVIEW2023Q1实时模块英文版下载RT23.1-32位
    前天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2023-3-16 09:31:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    自2011版实时模块起,NI提供了中文、日文、英语等三个语言版。本视觉论坛提供中文和英文版,部分日文版。自RTM2021版起,有64位的RT模块(仅英文版),之前的版本,仅32位版本。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    发布日期:2023/2/6
    包含的版本:2023 Q1完整版,版本号23.1.0
    语言:英文English
    应用程序位数:32位
    文件大小: 1893906432 字节 (1.76 GB)
    修改日期: 2023-02-07 21:52
    MD5: 4d58bf64b6eb560125586e55100ac060
    SHA1: e8274e4e621934413c9c92d9afde51f32d0a1817
    SHA256: 01f5d0b75ddaa42d1ddbc6fd41fabaf59e4a22723d46b5c95aa38f5cc2012905
    CRC32: 49516039
    请注册登录视觉论坛会员,购买附件查看
    RealTime2023Q1x86Eng.txt (606 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2023 Q1 Real-Time Module Readme
    January 2023
    This file contains installation instructions and compatibility information for LabVIEW 2023 Q1 Real-Time Module.
    • LabVIEW Real-Time Module Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW Real-Time Module Documentation: New features, behavior changes, and other documentation
    The Real-Time Module has the following requirements:
    • LabVIEW 2023 Q1 Full or Professional Development System
    • At least 200 MB of disk space in addition to the LabVIEW-recommended minimum
    Note
    • The Real-Time Module (32-bit) is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS. The Real-Time Module (64-bit) is compatible with LabVIEW (64-bit) only.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    The Real-Time Module supports the following operating systems for application development:
    Note  The Real-Time Module installs NI Linux Real-Time operating system.
    Note  NI Linux Real-Time OS supports only a subset of LabVIEW features. Refer to the Real-Time Module»Real-Time Operating Systems book on the Contents tab of the LabVIEW Help for a list of unsupported LabVIEW features and special considerations for NI Linux Real-Time OS.
    The LabVIEW 2023 Q1 Real-Time Module supports the following application software versions, including service packs.
    Versions Supported by the Real-Time Module
    LabVIEW2023 Q1
    Note
    • LabVIEW 2023 Q1 Real-Time Module 64-bit does not support Modbus IO server. As a wokaround, you can use the option of direct communication using the Modbus LabVIEW API.
    • LabVIEW 2023 Q1 Real-Time Module 32-bit and 64-bit does not support Real-Time Trace Viewer. You can use KernelShark, a similar open source tool, as an alternative.
    Download the Real-Time Module installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You also can install all of your LabVIEW products—including the Real-Time Module—using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    • Use the serial number that is included with your software to activate the Advanced Signal Processing Toolkit. For more information on the Real-Time Module activation, refer to NI Software Activation.
    Installing and Using Japanese and Simplified Chinese Languages on an RT Target
    After you install the Real-Time Module on your development computer, you can complete the following steps to install and use Japanese and Simplified Chinese languages on an RT target:
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer (NI MAX) to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target. Refer to the Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese or Simplified Chinese as the Locale.
    Note  You cannot use Japanese or Simplified Chinese characters in directory names or filenames on the RT target.
    Note  The Real-Time Module (64-bit) supports English only.
    Configuring RT Targets
    Use NI MAX to configure RT targets and to install software and drivers on targets. You can install NI MAX from the NI Package Manager or the LabVIEW Platform media.
    • Networked RT Targets—Refer to the Remote Systems book in the Measurement & Automation Explorer Help, available by selecting Help»MAX Help from MAX, for information about configuring networked RT targets.
    Note  If you install NI Web-based Configuration & Monitoring on an RT target, you can use a web browser to perform common monitoring and configuration tasks on the target. On the Contents tab in the LabVIEW Help, select Fundamentals»Working with Projects and Targets»How-To»Monitoring and Configuring a Remote Device from a Web Browser for information about NI Web-based Configuration & Monitoring.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Real-Time Module.
    LabVIEW Real-Time Module no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    举报
    GMT+8, 2025-6-2 04:25
