查看: 3693|回复: 0
[NI软件套件] NI Software Platform Bundle-x86-Eng_8.6_suite Win32Eng NI SPB8.6 32位英文版下载,基于LabVIEW8.6
    7 小时前
  • 签到天数: 3794 天
    连续签到: 45 天
     楼主| 发表于 2023-2-13 10:01:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LV8.6 DVD1.txt (414 Bytes, 下载次数: 0, 售价: 50 圆)
    SPB8.6源于NI发布的实体DVD光盘,因此没有官网下载地址。
    注:按NI早期发布的SPB平台级产品,应该是有2-3张开发者DVD+1张扩展工具包+1张驱动DVD这样的模式,对于SPB8.6,本论坛仅获得了DVD1。其它的可能存在的DVD2、DVD3、DVD4,没有相关资源。对于驱动光盘,可以尝试查看DCD资源,是否有相应的版本的,LV8.6发布于2008年6月,DCD 2008.05或2008.08应该匹配,至少2008.08是可以兼容使用的:
    NI Device Drivers full version downloads 美国国家仪器NI仪器驱动程序DCD全集下载DCD2007.08~DCD2019.01
    http://visionbbs.com/thread-23052-1-1.html?fromuid=9
    (出处: 机器视觉论坛)
    LabVIEW 8.6 Platform DVDs Readme
    June 2008
    With the LabVIEW Platform DVDs, one installation gives you access to nearly all products in the LabVIEW platform. Install modules and toolkits from the DVDs to ensure compatibility with LabVIEW 8.6. If you purchased any of these add-ons, you can install and activate them using the LabVIEW Platform DVDs. If you want to evaluate any of these add-ons before purchasing them, you can install these add-ons from the LabVIEW Platform DVDs and try them for free for 30 days.
    Installing, Evaluating, and Activating LabVIEW
    Installing Another Language Version
    LabVIEW Module and Toolkit Compatibility
    Readmes for Products on the LabVIEW Platform DVDs
    Refer to the LabVIEW Release Notes for information about installing, evaluating, and activating the LabVIEW Development System and LabVIEW modules and toolkits.
    Your LabVIEW software kit includes only DVDs. If you require LabVIEW on CDs, refer to the National Instruments Web site at ni.com/info and enter the info code lvcd.
    You can run the LabVIEW Platform installer on the following operating systems:
    • Windows Vista, including Windows Vista x64
    • Windows XP, excluding Windows XP x64
    • Windows 2000
    Note  The LabVIEW Platform installer does not support Windows NT/Me/98/95 or any of the WindowsServer editions.
    Refer to the LabVIEW Release Notes for a complete list of system requirements for the LabVIEW Development System and to the [url=]product readmes[/url] for additional module and toolkit system requirements.
    If you have another language version of LabVIEW 8.6 installed on your computer, uninstall that version before installing the new language version.
    Note  LabVIEW SignalExpress is a multilingual product that operates in the same language as the system locale for English, French, German, and Japanese. All other system locales default to the English version of LabVIEW SignalExpress. You do not need to uninstall LabVIEW SignalExpress to change languages.
    Use the LabVIEW Platform DVDs to ensure you install modules and toolkits that are compatible with LabVIEW 8.6. If the LabVIEW Platform DVDs do not include the module or toolkit you need, first refer to the LabVIEW Module and Toolkit Compatibility Information page for information about which modules and toolkits are compatible with the current version of LabVIEW. Then install the compatible module or toolkit in the LabVIEW 8.6 directory and mass compile any VIs that you saved in previous versions of LabVIEW.
    Some toolkit versions do not work with LabVIEW 8.6. If you attempt to install incompatible toolkit versions, you might corrupt your LabVIEW 8.6 installation. If you install an incompatible version and corrupt your LabVIEW 8.6 installation, first uninstall the toolkit and then repair the LabVIEW installation using Add or Remove Programs.
    Refer to the following readmes for information about each product on the LabVIEW Platform DVDs, including installation, activation, known issues, and bug fixes.
    • LabVIEW Development System
    • Adaptive Filter Toolkit
    • Advanced Signal Processing Toolkit
    • Application Builder
    • Control Design and Simulation Module
      • [url=]Control Design Assistant
    • Database Connectivity Toolkit
    • Datalogging and Supervisory Control Module
      • Datalogging and Supervisory Control Module Run-Time System
      • Statistical Process Control Toolkit
    • Digital Filter Design Toolkit
    • DSP Module
    • FPGA Module
    • nternet Toolkit
    • LabVIEW SignalExpress
      • English
      • French
      • German
      • Japanese
    • Microprocessor SDK
    • Mobile Module
    • NI Motion Assistant
    • PID Control Toolkit
    • Real-Time Execution Trace Toolkit
    • Real-Time Module
    • Report Generation Toolkit for Microsoft Office
    • Simulation Interface Toolkit
    • Statechart Module
    • System Identification Toolkit
    • Touch Panel Module
    • VI Analyzer Toolkit
    • Vision Development Module
    © 2003–2008 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2026-2-5 17:31
