查看: 2019|回复: 0
[LV第三方库] NI Database-DB for LabVIEW
    6 小时前
  • 签到天数: 3808 天
     楼主| 发表于 2022-12-7 17:05:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    DB for LabVIEW™ is a stand-alone program that allows you to automatically generate a driver VI for a database. This driver uses the LabVIEW™ Database Connectivity Toolkit so you need to install this toolkit in order to use DB for LabVIEW™.
    文件大小: 164228556 字节 (156.62 MB)
    修改日期: 2022-03-25 06:01
    MD5: 24837843804bbbbfa8ee1b52116faaa0
    SHA1: 9659a979343750a6b611b6c91678c4d4209c4792
    SHA256: 89f206b0978fe554a60b2ba7804916f4c8bb548926da7c1eb618661abac662f2
    CRC32: f0e471d8
    请注册登录视觉论坛账号,购买附件查看下载地址
    DBforLV.txt (501 Bytes, 下载次数: 0, 售价: 10 圆)
    DB for LabVIEW™ is a stand-alone program that allows you toautomatically generate a driver VI for a database. This driver uses theLabVIEW™ Database Connectivity Toolkit so you need to install this toolkit inorder to use DB for LabVIEW™.
    Instead of having to interface with variants with the LV DatabaseConnectivity Toolkit, use DB for LabVIEW to directly get clusters with theright data type.
    Here is a list of the main features:
    ·       Connect your existing database bydefining UDL file (Universal Data Link compatible with many types of databases)
    ·       Generate a unique polymorphic VIthat connects to every table of your database
    ·       The polymorphic VI adapts itsterminal types to the column data types of the table you've chosen
    ·       1 unique VI can execute"select", "insert", "update" and"delete" queries on every tables of your database
    ·       Update your database structureand regenerate the driver, and your LabVIEW code updates automatically with thenew database structure
    ·       And more...
    If this is the first time you are using thisproduct, you are strongly advised to visit the HELP system and follow theGetting Started guide.
    http://help.studiobods.com/dbforlabview
    This help system includes information about DB for LabVIEW, step-by-stepinstructions, and reference information about interfaces.
    GMT+8, 2026-2-25 16:40
