查看: 1522|回复: 0
[NI软件产品] NI SignalExpress 2015 Win32德语/日语/法语/英文 数据记录软件Signal Express 2015
    3 小时前
  • 签到天数: 3565 天
    连续签到: 10 天
     楼主| 发表于 2022-12-7 15:41:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SignalExpress
    SignalExpress​使​您​无​需​编​程​即可​记录、​分析​和​显示​测量​设备​的​数据。
    SignalExpress​是​一​款​交互​式​数据​记录​软件,​让​您​无​需​编​程,​即可​从​数百​种​数据​采集​仪器​和​设备​上​快速​采集、​分析​并​显示​数据。​SignalExpress​用户​可以​控制​400​多台​基于​PC​的​独立​仪器,​以及​来自​250​多个​数据​采集​设备​的​日志​数据。​该​软件​可以​处理​和​分析​信号,​并​将​结果​信号​发送​到​硬件​设备。​SignalExpress​还​提供​自动​LabVIEW​代码​生成​功能,​可​扩展​应用​程序。​用户​可以​轻松​创建​自​定义​报告,​并​将​其​导出​到​LabVIEW、​DIAdem​或​Microsoft Excel​中。
    发布日期:2015/6/26
    包含的版本:2015
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP (32-bit)
    Windows Server 2003 R2 (32-bit)
    Windows Server 2008 R2 (64-bit)
    语言:德语, 日语, 法语, 英文
    应用程序位数:32位
    文件大小: 1022464800 字节 (975.10 MB)
    修改日期: 2015-07-31 23:45
    MD5: a1a00df868fb2efdb11aaec0f6e143a3(官方正确)
    SHA1: aac773bdb0cacc9105203468a11c9fcb8b97d9aa
    SHA256: 7ed87b079813ff0ec27efe170cca2dec3c69d3d2ae0c537f34da67773ce0524b
    CRC32: 3df6a3fa
    请注册登录视觉论坛账号,购买附件查看下载地址
    SignalExpress2015.txt (591 Bytes, 下载次数: 0, 售价: 10 元)
    SignalExpress 2015 Readme
    June 2015
    This file contains important information about SignalExpress 2015, including system requirements, installation instructions, and known issues.
    Refer to the Getting Started with SignalExpress manual for getting started information by selecting Help»Getting Started with»Getting Started with SignalExpress in SignalExpress. You must have Adobe Reader installed to view the Getting Started with SignalExpress manual. Refer to the Adobe Systems Incorporated website at www.adobe.com to download the latest version of Adobe Reader.
    Compatibility with Driver Software
    Installing from the LabVIEW 2015 Platform Media
    Installing from the SignalExpress 2015 Installation Media
    Using Hardware with SignalExpress
    Activating SignalExpress
    SignalExpress Full Edition
    SignalExpress Limited Edition
    Code Generation Compatibility
    SignalExpress is an interactive measurement program to acquire, analyze, log, and present data from hundreds of data acquisition devices and instruments with no programming required. You can acquire signals from hardware devices installed on your computer, analyze the signals, and then send the resulting signals to hardware devices.
    SignalExpress has the following requirements:
    • Pentium 4 processor or equivalent
    • At least 2 GB of disk space
    • 1 GB RAM
      • Windows 8.0/8.1 (32-bit and 64-bit)
      • Windows XP SP3 (32-bit)
      Note
      • SignalExpress runs as a 32-bit application on all the operating systems in the previous list.
      • Support for Windows Server 2003 R2 may require disabling Physical Address Extension (PAE). Refer to the National Instruments website to learn how disabling PAE might affect your use of Windows Server 2003 and what actions you might have to take.
      • SignalExpress does not support Windows 2000/NT/Me/98/95, Windows XP (64-bit), or the Windows Server non-R2 editions.
    The following table lists the application software versions, including service packs, supported by SignalExpress.
    Application SoftwareVersions Supported by SignalExpress
    LabVIEW2012 (32-bit), 2013 (32-bit), 2014 (32-bit), 2015 (32-bit)
    SignalExpress is compatible with the following driver software:
    • NI-DAQmx 9.5.5 or later
    • NI-SCOPE 2.7 or later
    • NI-FGEN 2.2 or later
    • NI-DMM 2.4.1 or later
    • NI-HSDIO 1.3.1 or later
    • NI-HWS 1.3.1 or later
    • NI-DCPower 1.0 or later
    • IVI Compliance Package 14.0 or later
    SignalExpress installs the NI Measurement Studio Network Variable and Windows Forms support in the .NET Global Assembly Cache for run-time purposes.
    Installation InstructionsInstalling from the LabVIEW 2015 Platform Media
    If you purchased LabVIEW 2015, you can install all of your LabVIEW products—including SignalExpress—using the LabVIEW 2015 Platform media. Find installation instructions for SignalExpress, along with activation instructions, in the following locations:
    • LabVIEW Installation Guide, which is available in your LabVIEW software kit.
    • LabVIEW 2015 Platform Media Readme, which is available on the top-level of LabVIEW Platform media.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    Complete the following steps to install SignalExpress 2015 from the SignalExpress installation media.
    • Insert the SignalExpress 2015 installation media and follow the instructions that appear on the screen.
    • (Optional) Activate SignalExpress when prompted by the installer, or activate at a later time using the NI License Manager.
    If you purchased SignalExpress with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Complete the following steps to use SignalExpress with hardware:
    • Install the appropriate driver software according to the following table.
      HardwareDriver software
      Multifunction DAQNI-DAQmx
      High-speed digitizersNI-SCOPE
      Signal generatorsNI-FGEN
      Digital multimetersNI-DMM
      All driver software is available on the NI Device Drivers media.
    • Shut down the computer.
    • Install the hardware.
    • Restart the computer to complete the software installation.
    SignalExpress is available in full and limited (LE) editions. When you install SignalExpress, you have a 7-day trial of the Full Edition. After that period, you must purchase the Full Edition or activate SignalExpress LE.
    If you purchased the Full Edition of SignalExpress, you can activate from the software or the NI License Manager using the serial number included in your software kit. If you purchased the Full or Professional Development System of LabVIEW 2015, you can use the serial number included with LabVIEW to activate SignalExpress.
    Refer to ni.com/signalexpress to purchase the Full Edition.
    SignalExpress Limited Edition (LE)
    You can activate SignalExpress LE by clicking the Register Limited Edition button on the National Instruments License Dialog window that appears when you launch the application. You also can activate SignalExpress LE from the NI License Manager using the following serial number:
    S14X86772
    To convert a SignalExpress project to a LabVIEW VI, you must have the LabVIEW 2012 Full Development System or later installed.
    Note  SignalExpress does not support the 64-bit versions of LabVIEW.
    The following steps are deprecated in SignalExpress 2015:
    • Run LabVIEW 7.1 VI
    • Run LabVIEW 8.0 VI
    • Run LabVIEW 8.2 VI
    • Run LabVIEW 8.5 VI
    • Run LabVIEW 8.6 VI
    • Run LabVIEW 2009 VI
    • Run LabVIEW 2010 VI
    • Run LabVIEW 2011 VI
    To run a project that contains steps in the previous list, refer to the National Instruments website.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in SignalExpress 2015.
    Refer to the SignalExpress Help, accessible from Help»SignalExpress Help, for information about SignalExpress.
    You can modify an example project for an application, or you can copy and paste one or more examples into a project that you create. Example projects for SignalExpress are located in the signalexpress\examples directory. You can find the examples directory in one of the following ways:
    • Click Open Example Project for SignalExpress from the Getting Started window.
    • Select Help»Open Example from SignalExpress.
    Using NI Launcher
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI SignalExpress Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments SignalExpress will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of SignalExpress that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    © 2004–2015 National Instruments. All rights reserved.
    374767B-01
    举报
    GMT+8, 2025-6-12 10:43
