查看: 1192|回复: 0
[NI软件产品] NI SignalExpress 2009 Win32德语/日语/法语/英文 数据记录软件Signal Express 2009
  • 签到天数: 3535 天
     楼主| 发表于 2022-12-7 15:25:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SignalExpress
    SignalExpress​使​您​无​需​编​程​即可​记录、​分析​和​显示​测量​设备​的​数据。
    SignalExpress​是​一​款​交互​式​数据​记录​软件,​让​您​无​需​编​程,​即可​从​数百​种​数据​采集​仪器​和​设备​上​快速​采集、​分析​并​显示​数据。​SignalExpress​用户​可以​控制​400​多台​基于​PC​的​独立​仪器,​以及​来自​250​多个​数据​采集​设备​的​日志​数据。​该​软件​可以​处理​和​分析​信号,​并​将​结果​信号​发送​到​硬件​设备。​SignalExpress​还​提供​自动​LabVIEW​代码​生成​功能,​可​扩展​应用​程序。​用户​可以​轻松​创建​自​定义​报告,​并​将​其​导出​到​LabVIEW、​DIAdem​或​Microsoft Excel​中。
    发布日期:2009/9/26
    包含的版本:2009
    受支持的操作系统
    Windows 2000
    Windows XP
    语言:德语, 日语, 法语, 英文
    应用程序位数:32位
    文件大小: 708602400 字节 (675.78 MB)
    修改日期: 2009-07-15 05:42
    MD5: 1ca246627382f684d259c96c22ae4e1a(重复一致)
    SHA1: c934e6026d17e007a5ddfb025ef2d52ae9c4eda1
    SHA256: da1f15b59737848ceda0de169a6acc34b93702abef28e6ac18fb1369848d9656
    CRC32: dba226a7
    请注册登录视觉论坛账号,购买附件查看下载地址
    SignalExpress2009.txt (1.04 KB, 下载次数: 0, 售价: 10 元)
    LabVIEW SignalExpress 2009 Readme
    June 2009
    This file contains important information about LabVIEW SignalExpress 2009, including known issues, installation instructions, and compatibility issues. Refer to Getting Started with LabVIEW SignalExpress for information about getting started with LabVIEW SignalExpress. You can access this PDF by selecting Help»Getting Started with»LabVIEW SignalExpress in the LabVIEW SignalExpress environment.
    This file contains the following information that you need to understand.
    Supported Platforms
       Installing from the LabVIEW 2009 Platform DVDs
       Installing from the LabVIEW SignalExpress 2009 Installation Media
       Using Hardware with LabVIEW SignalExpress
    Compatibility
    Deprecated Steps
    LabVIEW SignalExpress is an interactive measurement program you can use to acquire, analyze, log, and present data from hundreds of data acquisition devices and instruments, with no programming required. Use LabVIEW SignalExpress to create projects that acquire, analyze, create, generate, and display signals. You can acquire signals from hardware devices installed on your computer, analyze the signals, and then send the resulting signals to hardware devices.
    Supported Platforms
    LabVIEW SignalExpress supports Windows Vista/XP/2000. LabVIEW SignalExpress does not support Windows NT/Me/98/95, any of the Windows Server editions, or Windows Vista/XP x64.
    To run LabVIEW SignalExpress, National Instruments recommends that your system meet the following requirements:
    • 1 GB of memory (512 MB minimum)
    • 2 GB of free disk space (1.5 GB minimum)
    • Pentium 4 processor or equivalent (866 MHz minimum)
    Note  If you are using Windows 2000, you must install Service Pack 4 and all additional critical updates before you install LabVIEW SignalExpress.
    (Windows Vista/XP/2000) If you purchased LabVIEW 2009, you can install all of your LabVIEW products—including LabVIEW SignalExpress—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for LabVIEW SignalExpress along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    Note  If you purchased the Full or Professional Edition of LabVIEW 2009, you also can use the serial number included with LabVIEW 2009 to activate LabVIEW SignalExpress. If you purchased the Base Package of LabVIEW 2009, you must purchase LabVIEW SignalExpress separately to obtain a separate serial number to activate LabVIEW SignalExpress.
    Complete the following steps to install LabVIEW SignalExpress 2009 from the LabVIEW SignalExpress installation media.
    • Insert the LabVIEW SignalExpress 2009 installation media and follow the instructions that appear on the screen.
    • (Optional) Activate LabVIEW SignalExpress when prompted by the installer, or activate at a later time using the NI License Manager.
    Note  LabVIEW SignalExpress LE is a free, limited version of LabVIEW SignalExpress that does not include all of the steps or features available in the Full Edition. When you install LabVIEW SignalExpress, you have a 30-day trial of the Full Edition of LabVIEW SignalExpress. After that period, you must activate LabVIEW SignalExpress LE or purchase the Full Edition.
    Complete the following steps to use LabVIEW SignalExpress with hardware.
    • Install the appropriate driver. For Multifunction DAQ, use NI-DAQmx. For high-speed digitizers, use NI-SCOPE. For signal generators, use NI-FGEN. For digital multimeters, use NI-DMM. All drivers are available on the Driver CD.
    • Shut down the computer.
    • Install the hardware.
    • Restart the computer to complete the software installation.
    Refer to the LabVIEW SignalExpress Help, accessible by selecting Help»LabVIEW SignalExpress Help in LabVIEW SignalExpress, for information about LabVIEW SignalExpress.
    Example projects for LabVIEW SignalExpress are located in the signalexpress\examples folder. You can modify an example project to fit an application, or you can copy and paste from one or more examples into a project that you create.
    Compatibility
    To convert a LabVIEW SignalExpress project to a LabVIEW VI, you must have the LabVIEW 8.2 Full Development System or later installed.
    Note  LabVIEW SignalExpress does not support the 64-bit version of LabVIEW 2009.
    LabVIEW SignalExpress is compatible with the following products:
    • NI-DAQmx 8.5 or later
    • NI-SCOPE 2.7 or later
    • NI-FGEN 2.2 or later
    • NI-HSDIO 1.3.1 or later
    • NI-HWS 1.3.1 or later
    • NI-DMM 2.4.1 or later
    • NI-DCPower 1.0 or later
    • IVI Driver Toolset 2.0 or later
    LabVIEW SignalExpress installs the NI Measurement Studio Network Variable and WindowsForms support in the .NET Global Assembly Cache for runtime purposes.
    Deprecated Steps
    The following steps are deprecated in LabVIEW SignalExpress 2009:
    • Run LabVIEW 7.1 VI
    • Run LabVIEW 8.0 VI
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW SignalExpress.
    The following items are the IDs and titles of a subset of issues fixed between LabVIEW SignalExpress 3.0 and LabVIEW SignalExpress 2009. This is not an exhaustive list of issues fixed in the current version of LabVIEW SignalExpress. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy IDFixed Issue
    301234F7AQSGXOutput names not correct when copying steps with different numbers of outputs
    301344EG9K63WLoad from LVM support for custom x-axis or y-axis units is incomplete
    30249430KTUI8Deleting the active log does not make the previous log active
    3027342TDIKI8Default Chart Display plot configuration does not display non-continuous scalar logs
    302783I3EDMRSCannot add sweep parameters to a second project if dialog is still open in first project
    3028344SBMUX1Cannot move divider in Table display
    3031442GA7UYGLED display does not scale properly
    304303AAG9L7WCannot arrange displays on Data View tab
    307114A9KBD0QCreate Analog Signal should allow user to set units for data
    30745459C7VK9Load from file Express VIs do not have file inputs after code generation
    307854599B7K9Limit Test Express VI does not import scalar limits during code generation
    307924A0D83LYRecord While Running state not saved with project
    308594STJGCI8Return subset of Subset and Resample step should be enabled by default
    30874440BCJ00Arithmetic step does not clear error while running
    524254B28OCN7Warning messages disappear too quickly
    97328-Events that occur before logging starts appear in Alarms and Events dialog
    107647-LabVIEW SignalExpress will not launch from shortcut if installed in non-default location
    107910-Clicking Run next iteration button in a Playback work area clears Chart Display
    109322-Create Log Subset allows you to edit axes and then expand range beyond limits of log
    110505-Errors with start/stop condition time stamps not reported
    110709-Context help missing for Operator Interface Font properties
    111131-Tab key focus lost on Playback Options tab
    111981-Window step preview graph always shows four elements
    112931-Limit Test preview graph does not display limit signals correctly
    114382-Tone Extraction graph for Exported Time Signal does not show units correctly
    115197-Error on undo after deleting a step while running
    116201-Exporting to ASCII file after logging causes error when acquiring in N Samples mode
    117619-Cannot import Channel View data from Excel if view was sorted by Measurement Type at export
    118331-Server polling rate from DAQmx appears with volts as units
    119194-Cannot load certain displays when System Identification Assistant or Control Design Assistant is installed
    119812-Crash opening Sound and Vibration Assistant project that writes to shared variables
    120787-Convert Analog to Digital returns an empty waveform when the input signal is out of range
    121024-Operator Interface control bound to Limit Test upper or lower limit does not work while running
    121185-Used and free disk space values incorrect on Recording Options tab
    122416-Non-waveform signals have white (invisible) plot 0 on Project Documentation tab
    122612-Crash when deleting multiple graphs from the Project Documentation tab
    124046-Exporting logged data to Excel loses the original time stamp
    124415-Autoscaling x axis does not work in certain cases
    124514-Project cannot load if Load from UFF58 step contains subgroup outputs
    124517-Subgroups not saved with project
    124584-Signal trigger stop condition does not stop logging at the correct time
    124652-Playback ignores Stop playback time
    124689-Alarm triggers Alarm OFF action on Alarm ON event
    125164-Formula step preview graph does not show signal names in legend
    125226-Create Log Subset context menu option does not work
    125759-Save to ASCII/LVM Express VI does not append data to file
    126360-Cannot import log if name contains special characters
    126908-Cannot play back log after defining subgroups
    126914-Cannot display frequency signal if scale is logarithmic but not autoscaled
    126935-Subgroup definition lost after changing Power Spectrum step configuration
    127178-LabVIEW SignalExpress cannot connect to Industrial IO Variables for EtherCAT
    127213-Conditional Repeat before a Sequence step results in Error 200587
    127288-Hang when Prepare log data for viewing is set to After logging completes
    127438-Chart display does not remember formatting when project is reopened
    127518-Reloading a project with a locked cursor results in cursor not being movable
    127535-Removing a signal from a display causes other signals to disappear
    127541-Missing execution events when performing offline analysis on a scalar log
    127545-Write to Shared Variable does not work on signals within a group
    127635-Adding sweepable parameters allowed in operator mode and can cause crash
    127882-Playback speed not saved with project
    128696-Cursors not supported for XY data
    129581-Crash when Prepare log data for viewing is set to After logging completes and Acquisition Mode is N Samples
    130081-LabVIEW SignalExpress does not output Digital Line value when recieving programmatic input
    130521-Cannot read LVM files saved in LabVIEW 8.6
    130536-Project file size increases when saving the project
    131022-Subgroups add extra rows to preview table in DAQmx Acquire step
    131412-Options not saved in LabVIEW SignalExpress or Sound and Vibration Assistant
    131461-Outputs of LabVIEW SignalExpress Express VI are constants
    131547-Crash opening project that writes to shared variables
    131992-Only first four outputs of synchronized steps are named correctly in generated LabVIEW code
    134172-Project hangs when Sequence step is deleted
    135488-Alarms and events that occur in the pretrigger section are not recorded
    134751-Sound and Vibration Assistant crashes when you delete a spectrum graph from the Project Documentation view
    140828-Logs created in LabVIEW SignalExpress 2.5 are not exportable in LabVIEW SignalExpress 3.0
    141397-Cannot export log subsets to Microsoft Excel
    142313-LabVIEW SignalExpress crashes when adding multiple signals to a table
    142589-Read Shared Variable steap fails to read data published by another project
    142687-Data View ignores log time stamps by default
    142863-Log titles do not update
    142905-LabVIEW SignalExpress ignores logging settings after warning
    142913-Clicking Acquire in the Channel View for a shared variable crashes LabVIEW SignalExpress
    143248-Event Viewer does not show user-specified events in a log
    143604-Digital Graph display does not display discontinuous logs correctly
    144590-Repeat start/stop cycle option on Start Conditions page of Recording Options tab resets to 1 when a second log is created
    144981-Load from ASCII cannot import comma-delimited files
    146609-Logging does not restart correctly when no start condition is specified
    147899-Data disappears from the Data View tab when Format and Precision is changed
    147938-Load from LVM step cannot load an LVM file that uses a localized decimal seperator
    149683-Data View tab does not always update multiple signals simultaneously
    150096-LabVIEW SignalExpress hangs when you acquire n samples with Automatically export log to ASCII file set to Yes
    150455-Dragging a signal from a data group to Wordpad crashes LabVIEW SignalExpress
    150573-Cannot view a subset of a non-continuous digital log
    150771-LabVIEW SignalExpress does not always play back entire log
    152834-Closing LabVIEW SignalExpress project with open signal probes can cause crash
    154231-Crash when you undo deleting a display from the Project Documentation view
    155116-Hang when removing the last signal from a display with a Preview Graph
    161327-Digital Graph display does not show correct signal names when you rename a signal
    161384-Subset and Resample step settings not saved with project
    163487-LabVIEW SignalExpress ignores Date/Time stop condition
    163531-Output of Time Averaging step not logged correctly
    165049-Scalar logs do not appear if dragged to the Data View tab during logging
    165108-Sample gets recorded twice in specific use case
    170092-Conditional Repeat step does not execute correctly when steps in loop are configured to reset on first call
    Important Information
    © 2004–2009 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-5-10 20:28
