查看: 1198|回复: 0
[NI软件产品] NI SignalExpress 2.0 Win32德语/日语/法语/英文 数据记录软件Signal Express 2.0
  • 签到天数: 3535 天
     楼主| 发表于 2022-12-7 15:15:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SignalExpress
    SignalExpress​使​您​无​需​编​程​即可​记录、​分析​和​显示​测量​设备​的​数据。
    SignalExpress​是​一​款​交互​式​数据​记录​软件,​让​您​无​需​编​程,​即可​从​数百​种​数据​采集​仪器​和​设备​上​快速​采集、​分析​并​显示​数据。​SignalExpress​用户​可以​控制​400​多台​基于​PC​的​独立​仪器,​以及​来自​250​多个​数据​采集​设备​的​日志​数据。​该​软件​可以​处理​和​分析​信号,​并​将​结果​信号​发送​到​硬件​设备。​SignalExpress​还​提供​自动​LabVIEW​代码​生成​功能,​可​扩展​应用​程序。​用户​可以​轻松​创建​自​定义​报告,​并​将​其​导出​到​LabVIEW、​DIAdem​或​Microsoft Excel​中。
    发布日期:2007/2/14
    包含的版本:2.0
    受支持的操作系统
    Windows 2000
    Windows XP
    语言:德语, 日语, 法语, 英文
    应用程序位数:32位
    文件大小: 387070752 字节 (369.14 MB)
    修改日期: 2007-03-03 02:13
    MD5: 5e39baee086436c950fd6798df4b1559
    SHA1: 70a8dab21fe2474ff900bfcae80840c1e0534ac3
    SHA256: 166e1fc7cff21b84dff377eb2dcdbe1fb26e3fecb29cb4d9955fc81a0c20f8be
    CRC32: 67115f59
    请注册登录视觉论坛账号,购买附件查看下载地址
    SignalExpress2.0.txt (475 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW SignalExpress 2.0 Readme
    January 2007
    Afficher ce fichier en français.
    このファイルを日本語で表示。
    This file contains important information about LabVIEW SignalExpress 2.0, including known issues, installation instructions, and compatibility issues. Refer to Getting Started with LabVIEW SignalExpress for information about getting started with LabVIEW SignalExpress. You can access this PDF by selecting Help»Getting Started with»LabVIEW SignalExpress in the LabVIEW SignalExpress environment.
    Place the LabVIEW SignalExpress CD in your CD-ROM drive and follow the prompts through the rest of the installation.
    Note  If you are using Windows 2000, you must install Service Pack 4 and all additional critical updates before you install LabVIEW SignalExpress
    Complete the following steps to use LabVIEW SignalExpress with hardware.
    • Install the appropriate driver. For Multifunction DAQ, use NI-DAQmx. For high-speed digitizers, use NI-SCOPE. For signal generators, use NI-FGEN. For digital multimeters, use NI-DMM. All drivers are available on the Driver CD.
    • Shut down the computer.
    • Install the hardware.
    • Restart the computer to complete the software installation.
    Compatibility Issues
    To convert a LabVIEW SignalExpress project to a LabVIEW VI, you must have the LabVIEW 7.1 Full Development System or later installed.
    LabVIEW SignalExpress is compatible with the following products:
    • NI-DAQmx 7.3 or later
    • NI-SCOPE 2.7 or later
    • NI-FGEN 2.2 or later
    • NI-HSDIO 1.3.1 or later
    • NI-HWS 1.3.1 or later
    • NI-DMM 2.4.1 or later
    • IVI Driver Toolset 2.0 or later
    LabVIEW SignalExpress will install or update the following applications:
    • MAX 4.2.1
    • LabVIEW Run-Time Engine 7.1
    • LabVIEW Run-Time Engine 8.0
    • LabVIEW Run-Time Engine 8.2
    • IVI Compliance Package 2.0 or later
    • NI-VISA 4.1.0
    • Microsoft .NET Framework 2.0
    LabVIEW SignalExpress also installs the NI Measurement Studio Network Variable and WindowsForms support in the Global Assembly Cache for runtime purposes.
    • When you convert a project to a LabVIEW block diagram, some VIs will contain errors. Mass compile the LabVIEW\vi.lib directory to fix the VIs.
    • If you are installing both the System Identification Toolkit 3.0 and LabVIEW SignalExpress 2.0, you must install the System Identification Toolkit 3.0 before you install LabVIEW SignalExpress 2.0. Installing the System Identification Toolkit 3.0 after you install LabVIEW SignalExpress results in an error upon launch of LabVIEW SignalExpress 2.0. To resolve the error, you can uninstall the affected components and reinstall in the correct order. The easiest way to resolve the error is to install the free System Identification Toolkit 3.0.1 upgrade. Refer to ni.com for more information on obtaining the free System Identification Toolkit 3.0.1 upgrade CD.
    • LabVIEW SignalExpress only supports one version of LabVIEW at a time. When you install LabVIEW SignalExpress, it finds the most current installed version of LabVIEW and installs support for LabVIEW SignalExpress into that version. If you later install a new version of LabVIEW, you need to uninstall and reinstall LabVIEW SignalExpress. When you reinstall, LabVIEW SignalExpress will install support for the new version of LabVIEW.
    • When you convert a project that contains features not supported in LabVIEW to a LabVIEW block diagram, LabVIEW SignalExpress generates a LabVIEW block diagram with one Express VI. You cannot open the block diagram of the generated Express VI. If you include the generated Express VI in a distribution with the LabVIEW Application Builder, you must install LabVIEW SignalExpress to any target computers on which you run the LabVIEW-built application.
    • Registration information is saved on a per-user basis in Windows Vista. When you change users, the user information that appears when you launch LabVIEW SignalExpress may appear incorrectly.
    • Creating a source distribution in LabVIEW of a LabVIEW SignalExpress User Step template VI may fail and return an error. For one possible solution for this error, navigate to the Additional Exclusions page of the Source Distribution Properties dialog box and select the Remove unreferenced project library members option to remove the error.
    • LabVIEW SignalExpress only supports one version of LabVIEW at a time for project conversion into LabVIEW. LabVIEW SignalExpress only installs support for the latest version of LabVIEW installed on the system. However, when you convert a LabVIEW SignalExpress project to a LabVIEW block diagram, LabVIEW SignalExpress calls the last version of LabVIEW opened on the system. If the last version of LabVIEW open on the system is not the version of LabVIEW with LabVIEW SignalExpress support installed, you must launch the version of LabVIEW with LabVIEW SignalExpress support and re-generate the project.
    • The Getting Started with LabVIEW SignalExpress manual incorrectly states that LabVIEW SignalExpress is compatible with Windows NT. LabVIEW SignalExpress is compatible with Windows Vista/XP/2000.
    • The LabVIEW SignalExpress Help incorrectly states that LabVIEW SignalExpress LE by default does not display steps that are only available in the Full Edition. LabVIEW SignalExpress LE by default does display steps that are only available in the Full Edition.
    • The Statistics step does not accept U32 data as an input.
    • When viewing scalar data in a table, the data history of the scalar data is not saved unless you previously viewed the scalar data in a chart display.
    • The Save to ASCII/LVM step does not save any units associated with the specified data.
    • You can configure only one IVI session name for a driver. If you configure more than one IVI session name for a driver, you invalidate existing IVI session names for that driver.
    • LabVIEW prompts you with a warning dialog box during project conversion if LabVIEW loads vi.lib subVIs from the National Instruments\LabVIEW directory rather than from the directory in which you saved your LabVIEW SignalExpress project. Click the OK button to resume conversion.
    • The Load from ASCII, Load from LVM, and Load from SPICE steps convert up to 20 imported signals into the LabVIEW VI during project conversion. If you want to import more than 20 signals and then convert the project to a LabVIEW VI, use two or more Load from ASCII, Load from LVM, or Load from SPICE steps.
    • You cannot convert a LabVIEW SignalExpress project to a LabVIEW block diagram if a hardware step in the project uses software triggers.
    • Text in any step configuration view does not display correctly if you set your monitor resolution to 1400 x 1050 or higher or if you use large fonts.
    • Due to driver and operating system issues, absolute time stamps have an inaccuracy of 100 ms to 200 ms. National Instruments recommends that you use relative time stamps.
    • You cannot use a software trigger if the IVI FGEN Standard Function step or the IVI FGEN Arbitrary Waveform step are in continuous generation mode or if the IVI FGEN steps are in a sweep operation. During a sweep operation, the NI-FGEN devices send a start trigger only at the first sweep iteration.
    • If you configure a device to start on a digital trigger and the trigger source is the start trigger of an analog output NI-DAQmx supported device, the device might receive the start trigger before the generation starts. This can occur the first time you run the project or on the first iteration of a continuous execution. To work around this issue, configure the analog output device to be a slave by configuring the device with a digital trigger and selecting a trigger signal from another device as the trigger source.
    © 2004–2007 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-5-10 19:39
