查看: 1324|回复: 0
[NI软件产品] NI SignalExpress 1.1 Win32德语/日语/法语/英文 数据​记录​软件Signal Express1.1
    12 小时前
  • 签到天数: 3535 天
     楼主| 发表于 2022-12-7 15:03:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI SignalExpress 1.1 Win32德语/日语/法语/英文 数据记录软件Signal Express1.1
    SignalExpress
    SignalExpress​使​您​无​需​编​程​即可​记录、​分析​和​显示​测量​设备​的​数据。
    SignalExpress​是​一​款​交互​式​数据​记录​软件,​让​您​无​需​编​程,​即可​从​数百​种​数据​采集​仪器​和​设备​上​快速​采集、​分析​并​显示​数据。​SignalExpress​用户​可以​控制​400​多台​基于​PC​的​独立​仪器,​以及​来自​250​多个​数据​采集​设备​的​日志​数据。​该​软件​可以​处理​和​分析​信号,​并​将​结果​信号​发送​到​硬件​设备。​SignalExpress​还​提供​自动​LabVIEW​代码​生成​功能,​可​扩展​应用​程序。​用户​可以​轻松​创建​自​定义​报告,​并​将​其​导出​到​LabVIEW、​DIAdem​或​Microsoft Excel​中。
    发布日期:2005/2/1
    包含的版本:1.1
    受支持的操作系统
    Windows 2000
    Windows XP
    语言:德语, 日语, 法语, 英文
    应用程序位数:32位
    文件大小: 209902272 字节 (200.18 MB)
    修改日期: 2005-03-26 01:22
    MD5: f14faa13fa8de949f23d3d251abe3381
    SHA1: b730e98967c2611ff451b1d7fe7e543d3699f4ed
    SHA256: 0d465902965df8b6331de43a55fa74d9b967e5b19aa0d1106026c954e3e8e860
    CRC32: 00ebc104
    请注册登录视觉论坛账号,购买附件查看下载地址
    SignalExpress1.1.txt (497 Bytes, 下载次数: 0, 售价: 10 元)
    NI SignalExpress 1.1 Readme
    March 2005
    This file contains important information about SignalExpress 1.1, including known issues, installation, and compatibility issues. Refer to the Getting Started with SignalExpress for information about getting started with SignalExpress. You can access this PDF by selecting Help»Getting Started with SignalExpress in the Express Workbench environment.
    • SignalExpress 1.1 contains five new IVI Instrument Steps to simplify connectivity to more than 300 different standalone instruments. The IVI Instrument Steps support IVI-C Drivers and are currently provided in SignalExpress 1.1 with minimal documentation. In addition, SignalExpress 1.1 projects containing the IVI Instrument Steps do not currently support conversion to LabVIEW VIs using the Express Workbench Project Conversion utility in LabVIEW 7.1. A SignalExpress maintenance release is scheduled and underway for release shortly after SignalExpress 1.1 to provide full documentation and project conversion support for the IVI Instrument Steps in SignalExpress. Refer to ni.com/support for any questions regarding this functionality and release schedule.
    • You can configure only one IVI logical name for a driver. If you configure more than one IVI logical name for a driver, you invalidate existing IVI logical names for that driver.
    • If you delete an IVI logical name in MAX without deleting its corresponding hardware asset, SignalExpress steps using that name fail and you cannot recreate that same name within SignalExpress. You must create a new IVI logical name in SignalExpress or delete the corresponding hardware asset in MAX.
    • LabVIEW prompts you with a warning dialog box during project conversion if LabVIEW loads vi.lib subVIs from the National Instruments\LabVIEW 7.1 directory rather than from the directory where you saved your project. Click the OK button to resume conversion.
    • The Load from ASCII, Load from LVM, and Load from SPICE steps will convert only 20 imported signals into the LabVIEW VI during project conversion. If you want to import more than 20 signals and then convert the project to a LabVIEW VI, use two or more Load from ASCII, Load from LVM, or Load from SPICE steps.
    • You cannot convert an Express Workbench project to a LabVIEW block diagram if that project uses software triggers.
    • Text in any step configuration view does not display correctly if you set your monitor resolution to 1400 x 1050 or higher or if you use large fonts.
    • Due to driver and operating system issues, absolute time stamps have an inaccuracy of 100 ms to 200 ms. National Instruments recommends that you use relative time stamps.
    • You cannot use Start Trigger from the NI-FGEN Standard Function step or the NI-FGEN Arbitrary Waveform step in continuous generation mode if the NI-FGEN steps are in a sweep operation. The reason is that during a sweep operation, the NI-FGEN devices only send a start trigger at the first sweep iteration.
    • If you configure a device to start on a digital trigger and the trigger source is the start trigger of an analog output DAQmx device, the device might receive the start trigger before the generation starts. This can occur the first time you run the project or on the first iteration of a continuous execution. To work around this issue, configure the analog output device to be a slave by configuring the device with a digital trigger, and selecting a trigger signal from another device as the trigger source.
    Place the SignalExpress CD in your CD-ROM drive and follow the prompts through the rest of the installation.
    Complete the following steps to use SignalExpress with hardware
    • Install the appropriate driver for that hardware. For Multifunction DAQ, use DAQmx. For High-Speed Digitizers, use NI-SCOPE. For Signal Generators, use NI-FGEN. For Digital Multimeters, use NI-DMM. All drivers are available on the Driver CD.
    • Shut down the computer.
    • Install the hardware.
    • Restart the computer to complete the software installation.
    Compatibility Issues
    SignalExpress is compatible with the following products:
    • DAQmx 7.3 or later
    • NI-SCOPE 2.7 or later
    • NI-FGEN 2.2 or later
    • NI-HSDIO 1.3.1 or later
    • NI-HWS 1.3.1 or later
    • NI-DMM 2.4.1 or later
    • IVI Compliance Package 2.0 or later
    • IVI Driver Toolset 2.0 or later
    The NI-HSDIO, NI-HWS, NI-DMM, Convert Analog to Digital, Convert Digital to Analog, Digital Compare, and the IVI steps are new for SignalExpress 1.1 and are not available in SignalExpress 1.0.
    To convert an Express Workbench project to a LabVIEW VI, you must have the LabVIEW 7.1 Full Development System or greater installed.
    The Wait on previous step control in the NI-DAQmx Acquire and NI-SCOPE Acquire steps is replaced by the Start this step after control. Use this control to specify what other step to wait for before starting the step.
    SignalExpress will install or update the following applications:
    • MAX 3.1.1
    • LabVIEW Run-Time Engine 7.1
    • LabVIEW Run-Time Engine 7.0
    © 2004, 2005 National Instruments Corporation. All rights reserved.
    FireWire® is the registered trademark of Apple Computer, Inc.
    Handle Graphics®, MATLAB®, Real-Time Workshop®, Simulink®, and Stateflow® are registered trademarks, and TargetBox2™, xPC TargetBox2™, and Target Language Compiler™ are trademarks of The MathWorks, Inc.
    Tektronix® and Tek are registered trademarks of Tektronix, Inc.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    GMT+8, 2025-5-10 21:47
