查看: 1450|回复: 0
[LV工具模块] LabVIEW 2009 Embedded Module for Blackfin Processors Win32Eng LabVIEW用于Blackfin管理器嵌入式模块LVEMBBF2009
    9 小时前
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2022-12-7 11:52:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2009/06/10
    包含的版本:2009
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP Service Pack 2 or later
    Windows Server 2003 R2 (32-bit)
    Windows Server 2008 R2 (64-bit)
    语言:英语/韩语
    应用程序位数:32位
    文件大小: 2300248064 字节 (2.14 GB)
    修改日期: 2022-03-25 06:04
    MD5: 4e3b69520fe41c83a5116866aa1b16dc
    SHA1: ab47517cf8b3c372f238129768ae848d0a7b73d0
    SHA256: c74e98023cc3d0d2eb02f043d17e5218da2d52889d580e1496978047b142795a
    CRC32: b034e0c6
    请注册登录视觉论坛账号,购买附件查看下载地址
    LVEMBBF2009.txt (521 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2009 Embedded Module for Blackfin Processors Readme
    June 2009
    This file contains important information about the LabVIEW Embedded Module for Blackfin Processors.
    Installation
    You can find installation instructions for the Embedded Module for Blackfin Processors with activation instructions in the Getting Started with the NI LabVIEW Embedded Module for ADI Blackfin Processors manual, which is available in your module software kit and online at ni.com/manuals.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Embedded Module for Blackfin Processors.
    The following table contains the IDs and titles of a subset of issues fixed in LabVIEW 2009 Embedded Module for Blackfin Processors. This table is not an exhaustive list of issues fixed in the current version of the Embedded Module for Blackfin Processors. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy IDDescription
    139188Parent VI exits before Timed Loop finishes execution
    137496Disabling interrupts inside a Timed Loop interrupt callback causes linker errors
    129653Linker error when building VI using BF Complex Matrix x Matrix Multiply VI
    118495Enabling Optimize subVI calls in build specifications sometimes causes the build to fail
    388533IR9ELO9Call Chain function cannot be used with Timed Loops
    Important Information
    © 2009 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-31 19:24
