查看: 1714|回复: 0
[LV工具模块] LabVIEW 2012 Embedded Module for ARM Microcontrollers Win32Eng/Kor LabVIEW用于ARM微控制器嵌入式模块EMBARM2012
    昨天 08:04
  • 签到天数: 3559 天
    连续签到: 4 天
     楼主| 发表于 2022-12-6 16:02:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2012/06/06
    包含的版本:2012
    受支持的操作系统
    Windows 7 (32-bit)
    Windows Vista (32-bit)
    Windows XP with Service Pack 3 (32-bit)
    语言:英语/韩语
    应用程序位数:32位
    ENG英文版:
    文件大小: 1663474312 字节 (1.55 GB)
    修改日期: 2022-03-25 05:50
    MD5: 4b1acb5a7fda654fec715bfcae97da1f
    SHA1: 7ae2abce49a3f5e1f8ba31177b7e18c4ffcdec2d
    SHA256: 9ecbaaed9894d05d83187db748cf6693c292bada59330ba1d7a1f715ef87c1e3
    CRC32: 8b64e93c
    LVEMBARM2012Eng.txt (517 Bytes, 下载次数: 3, 售价: 10 元)
    KOR韩语版:
    文件大小: 1727564424 字节 (1.61 GB)
    MD5: 87335df4969836d05f8866c616b28939
    SHA1: 5cf2ea1ff14e68d372ef2e31520bf7cdcb3bb1ad
    SHA256: 5b9f307daaf6ccd61c6d43774dfe947e19f2a7112b96634497c3933d194b8b3e
    CRC32: 0f701b58
    请注册登录视觉论坛账号,购买附件查看下载地址
    LVEMBARM2012Kor.txt (524 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2012 Embedded Module for ARM Microcontrollers Readme
    Version 12.0.0
    June 2012
    This file contains important information about the LabVIEW Embedded Module for ARM Microcontrollers.
    Installing the Embedded Module for ARM Microcontrollers
    The Embedded Module for ARM Microcontrollers has the following system requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit)
    • RealView Microcontroller Development Kit 4.11, including Keil μVision4
    • Keil ULINK2 USB-JTAG adaptor
    The Embedded Module for ARM Microcontrollers supports the following operating systems:
    • Windows 7 (32-bit)
    • Windows Vista (32-bit)
    • Windows XP with Service Pack 3 (32-bit)
    The Embedded Module for ARM Microcontrollers does not support Windows NT/Me/98/95/2000, Windows Server non-R2 editions, or the Windows Server 2008 R2 edition. Keil μVision does not support Windows Server.
    You must install the RealView Microcontroller Development Kit and activate the Keil μVision License ID Code (LIC) before you install the Embedded Module for ARM Microcontrollers. You can find installation instructions Embedded Module for ARM Microcontrollers with activation instructions in the Getting Started with the LabVIEW Embedded Module for ARM Microcontrollers manual, which is available in your module software kit and online at ni.com/manuals.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Embedded Module for ARM Microcontrollers.
    Refer to the National Instruments website for an up-to-date list of fixed issues in the Embedded Module for ARM Microcontrollers. This is not an exhaustive list of issues fixed in the current version of the Embedded Module for ARM Microcontrollers. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Embedded Module for ARM Microcontrollers.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Embedded Module for ARM Microcontrollers are located in the labview\examples\lvemb\arm directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2008–2012 National Instruments. All rights reserved.
    ARM, Keil, and μVision are trademarks or registered trademarks of ARM Ltd or its subsidiaries.
    GMT+8, 2025-6-7 04:02
