查看: 1214|回复: 0
[LV工具模块] LabVIEW 2014 Multicore Analysis and Sparse Matrix Toolkit Win32/64Eng LabVIEW多核分析和稀疏矩阵工具包2014
    9 小时前
  • 签到天数: 3554 天
    连续签到: 6 天
     楼主| 发表于 2022-12-6 12:18:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW Multicore Analysis and Sparse Matrix Toolkit
    LabVIEW Multicore Analysis and Sparse Matrix工具包可帮助您创建用于性能敏感型数学和分析算法的应用程序。
    LabVIEW Multicore Analysis and Sparse Matrix工具包是一款附加软件,提供了LabVIEW中使用的多线程分析库。该附加软件可用于需要在线处理或在离线场景下处理大型数据集的应用程序。该附加软件还具有稀疏线性代数功能,包括线性代数和矩阵运算,并通过可用库支持单精确度数据。LabVIEW Multicore Analysis and Sparse Matrix工具包支持通过 LabVIEW Real-Time模块在Windows PC和LabVIEW Real-Time (ETS)操作系统上执行。
    发布日期:2014/6/10
    包含的版本:2014
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP Service Pack 2 or later
    Windows Server 2003 R2 (32-bit)
    Windows Server 2008 R2 (64-bit)
    Full完整版
    文件大小: 150721312 字节 (143.74 MB)
    修改日期: 2022-03-25 06:09
    MD5: f087c2bfdba33635206ca1e90a3fbb76
    SHA1: 6f41e9dea923339f717d27abd107a20e41398c96
    SHA256: f62b221126ba14ed1ebbbcc872a07e0667fe8b3f3a9c8d71b5754b1dc9211294
    CRC32: 5c08f712
    请注册登录视觉论坛账号,购买附件查看下载地址
    MASMT2014.txt (668 Bytes, 下载次数: 1, 售价: 10 元)
    RTE运行版
    文件大小: 58376992 字节 (55.67 MB)
    修改日期: 2022-03-26 00:08
    MD5: 4d348066518770b7796a811a9c9f6a7e
    SHA1: dfda79b4ccbed70a6616ae46a11c19e3570629a3
    SHA256: 59b57e4f56f244553bf79fc92812a5862bebc59bdce294f8205bd328e1675b2a
    CRC32: c84d68ce
    MASMT2014RTE.txt (594 Bytes, 下载次数: 0, 售价: 5 元)
    LabVIEW 2014 Multicore Analysis and Sparse Matrix Toolkit Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW Multicore Analysis and Sparse Matrix Toolkit, including installation instructions and known issues.
    The LabVIEW Multicore Analysis and Sparse Matrix Toolkit enables you to create applications that leverage multicore technologies for computing performance-sensitive mathematics and analysis algorithms. The Multicore Analysis and Sparse Matrix Toolkit also provides sparse matrix data types and VIs which enable you to solve large-scale problems that dense matrices are unable to handle. The Multicore Analysis and Sparse Matrix VIs support single-precision and double-precision floating-point numbers. You can use the Multicore Analysis and Sparse Matrix Toolkit on Windows and NI ETS real-time operating systems only.
    In addition to the system requirements for the LabVIEW Development System, the Multicore Analysis and Sparse Matrix Toolkit has the following requirements:
    • LabVIEW 2014 Full or Professional Development System (32-bit or 64-bit)
    • At least 1 GB of disk space
    • 2 GB RAM recommended
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    Double-click the setup.exe file in the root directory of the Multicore Analysis and Sparse Matrix Toolkit installer and follow the instructions on the screen to install this product.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Multicore Analysis and Sparse Matrix Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Multicore Analysis and Sparse Matrix Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Multicore Analysis and Sparse Matrix Toolkit are located in the labview\examples\Multicore Analysis and Sparse Matrix directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Multicore Analysis and Sparse Matrix Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Multicore Analysis and Sparse Matrix Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW Multicore Analysis and Sparse Matrix Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2011–2014 National Instruments. All rights reserved.
    举报
    GMT+8, 2025-5-30 16:53
