查看: 1272|回复: 0
[LV工具模块] LabVIEW 2013 Multicore Analysis and Sparse Matrix Toolkit Win32/64Eng LabVIEW多核分析和稀疏矩阵工具包2013
    3 小时前
  • 签到天数: 3521 天
    连续签到: 9 天
     楼主| 发表于 2022-12-6 12:15:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW Multicore Analysis and Sparse Matrix Toolkit
    LabVIEW Multicore Analysis and Sparse Matrix工具包可帮助您创建用于性能敏感型数学和分析算法的应用程序。
    LabVIEW Multicore Analysis and Sparse Matrix工具包是一款附加软件,提供了LabVIEW中使用的多线程分析库。该附加软件可用于需要在线处理或在离线场景下处理大型数据集的应用程序。该附加软件还具有稀疏线性代数功能,包括线性代数和矩阵运算,并通过可用库支持单精确度数据。LabVIEW Multicore Analysis and Sparse Matrix工具包支持通过 LabVIEW Real-Time模块在Windows PC和LabVIEW Real-Time (ETS)操作系统上执行。
    发布日期:2013/6/10
    包含的版本:2013
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP Service Pack 2 or later
    Windows Server 2003 R2 (32-bit)
    Windows Server 2008 R2 (64-bit)
    Full完整版
    文件大小: 148886304 字节 (141.99 MB)
    修改日期: 2022-03-25 06:09
    MD5: 37cdbd60108e42a2b56da92890234356
    SHA1: 92b5199037785ceaa07ba6ad4eb98e519b25e456
    SHA256: 01792a02b12d11ecc2da519e0afdfa36daca2d646bb3f6db19081b67b4d003a9
    CRC32: c69ac804
    请注册登录视觉论坛账号,购买附件查看下载地址
    MASMT2013.txt (668 Bytes, 下载次数: 0, 售价: 10 元)
    RTE运行版
    文件大小: 56840992 字节 (54.21 MB)
    修改日期: 2022-03-26 00:08
    MD5: 28d0c29d1f9fa3b0b9cf856dedab28ac
    SHA1: 9dba380b863056600e884a58eb4952554df874f5
    SHA256: db96ee9f058c31f4ea130782d87b9568b57d2829c643396b3fe8ddf188e46bd5
    CRC32: d4d8a40f
    MASMT2013RTE.txt (594 Bytes, 下载次数: 0, 售价: 5 元)
    LabVIEW 2013 Multicore Analysis and Sparse Matrix Toolkit Readme
    Version 13.0.0
    June 2013
    This file contains information about the LabVIEW 2013 Multicore Analysis and Sparse Matrix Toolkit, including installation instructions, new features, and known issues.
    The LabVIEW Multicore Analysis and Sparse Matrix Toolkit enables you to create applications that leverage multicore technologies for computing performance-sensitive mathematics and analysis algorithms. The Multicore Analysis and Sparse Matrix Toolkit also provides sparse matrix data types and VIs which enable you to solve large-scale problems that dense matrices are unable to handle. The Multicore Analysis and Sparse Matrix VIs support single- and double-precision floating-point numbers. You can use the Multicore Analysis and Sparse Matrix Toolkit on Windows and NI ETS real-time operating systems only.
    In addition to the system requirements for the LabVIEW Development System, the Multicore Analysis and Sparse Matrix Toolkit has the following requirements:
    • LabVIEW 2013 Full or Professional Development System (32-bit or 64-bit)
    • At least 1 GB of disk space
    • 2 GB RAM recommended
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    Double-click the setup.exe file in the root directory of the Multicore Analysis and Sparse Matrix Toolkit installer and follow the instructions on the screen to install this product.
    Multicore Analysis and Sparse Matrix Toolkit Updates and Notifications
    The Multicore Analysis and Sparse Matrix Toolkit 2013 introduces the following new features.
    New Palettes
    • Fitting VIs—Use the Fitting VIs to perform curve fitting analysis or regression. This palette contains the following new VI:
      • Linear Fit—Use the Linear Fit VI to return the linear fit of a data set.
    • Probability & Statistics VIs—Use the Probability and Statistics VIs to perform probability, descriptive statistics, analysis of variance, and interpolation functions. This palette contains the following new VIs:
      • Mean—Use the Mean VI to compute the mean value of an input sequence.
      • RMS—Use the RMS VI to compute the root mean square of an input sequence.
    • Windows VIs—Use the Windows VIs to implement smoothing windows and to perform data windowing. This palette contains the following new VI:
      • Flat Top Window—Use the Flat Top Window VI to apply a flat top window to an input sequence.
    • Filters VIs—Use the Filters VIs to implement IIR, FIR, and nonlinear filters. This palette contains the following new VIs:
      • FIR Windowed Coefficients—Use the FIR Windowed Coefficients VI to generate the set of filter coefficients to implement an FIR windowed filter.
      • FIR Filter—Use the FIR Filter VI to filter an input sequence.
    New VIs
    The Signal Operation palette includes the following new VIs:
    • Decimate (single shot)—Use the Decimate (single shot) VI to decimate an input sequence.
    • Upsample—Use the Upsample VI to insert zeros in an input sequence.
    • Resample (constant to constant)—Use the Resample (constant to constant) VI to resample an input signal.
    Changed VIs
    The Convolution VI includes the following new instances:
    • 1D Convolution (DBL, CDB)
    • 1D Convolution (SGL, CSG)
    • 1D Convolution (CDB, DBL)
    • 1D Convolution (CSG, SGL)
    The Cross Correlation VI includes the following new instances:
    • 1D Cross Correlation (DBL, CDB)
    • 1D Cross Correlation (SGL, CSG)
    • 1D Cross Correlation (CDB, DBL)
    • 1D Cross Correlation (CSG, SGL)
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Multicore Analysis and Sparse Matrix Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Multicore Analysis and Sparse Matrix Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Multicore Analysis and Sparse Matrix Toolkit are located in the labview\examples\Multicore Analysis and Sparse Matrix Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI Multicore Analysis and Sparse Matrix Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Multicore Analysis and Sparse Matrix Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Multicore Analysis and Sparse Matrix Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2011–2013 National Instruments. All rights reserved.
    GMT+8, 2025-4-22 12:48
