查看: 1068|回复: 0
[LV工具模块] LabVIEW 2013 Wireless Sensor Network Module Pioneer Win32Eng LabVIEW无线传感器网络模块开发者2013
  • 签到天数: 3533 天
    连续签到: 3 天
     楼主| 发表于 2022-12-5 15:38:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2013/9/10
    包含的版本:2013
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista with Service Pack 1.0 (32-bit)
    Windows XP with Service Pack 3 (32-bit)
    Windows Server 2003 R2 (32-bit)
    应用程序位数:32位
    文件大小: 921219872 字节 (878.54 MB)
    修改日期: 2022-03-25 06:04
    MD5: 5cedab1b0be09c68139962a974265d87(秒传)
    SHA1: 601b32488c6b0badf9ecf16153dc9466dcd4e9f8
    SHA256: 1cc73aef163ab2b838f83a164f2b4bf908fa3704f3898cfdc7c185094fa66f49
    CRC32: f4e402d3
    请注册登录视觉论坛账号,购买附件查看下载地址
    LVWSN2013.txt (543 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2013 Wireless Sensor Network Module Pioneer Readme
    Version 13.0.0
    November 2013
    This file contains important information about the Wireless Sensor Network Module, including installation instructions and known issues.
    In addition to the system requirements for the LabVIEW Development System, the Wireless Sensor Network Module has the following requirements:
    • LabVIEW 2013 Base, Full, or Professional Development System (32-bit)
    • At least 2.5 GB of disk space
    • NI WSN-9791 Ethernet Gateway, NI 9792 WSN Real-Time Gateway, or an NI CompactRIO system with an NI 9795 C Series WSN Gateway
    • NI WSN-32xx WSN Nodes
    Refer to the LabVIEW readme for additional system requirements and supported operating systems for LabVIEW 2013.
    Complete the following steps to install the Wireless Sensor Network Module.
    • Log in as an administrator or as a user with administrator privileges.
    • Install LabVIEW using the LabVIEW 2013 Platform DVDs, if not already installed. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
      To request additional LabVIEW Platform DVDs, refer to the National Instruments website at ni.com.
    • Insert the NI LabVIEW Wireless Sensor Network Module media. If the installer does not automatically begin, double-click autorun.exe on the media to begin installation.
    • Select Install LabVIEW Wireless Sensor Network Module.
    • Follow the instructions on the screen for installing the Wireless Sensor Network Module.
    • Activate the Wireless Sensor Network Module.
      You must activate the Wireless Sensor Network Module before you can build VIs into WSN applications. The Wireless Sensor Network Module runs in evaluation mode if you do not activate it. You also can use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager or from NI Launcher in Windows 8, to activate National Instruments products. Refer to the National Instruments License Manager Help, available by selecting Help»Contents in the National Instruments License Manager, for more information about activating NI products.
    • Install and configure the NI Wireless Sensor Network devices. Refer to the NI Wireless Sensor Network Devices Getting Started Guide manual for installation instructions.
    Visit ni.com/security for security information about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Wireless Sensor Network Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Wireless Sensor Network Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Wireless Sensor Network Module are located in the labview\examples\lvemb\wsn directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Windows 8.xDesktopStart screenRight-click application and select Pin to Start
    Finding All Programs
    NI LabVIEW Wireless Sensor Network Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Wireless Sensor Network Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Wireless Sensor Network Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2009–2013 National Instruments. All rights reserved.
    GMT+8, 2025-5-8 01:19
