查看: 1552|回复: 0
[NI软件产品] NI Spectral Measurements Toolkit 2.6.1 Win32/64Eng NI频谱测量工具包SMT2.6.1
  • 签到天数: 3696 天
    连续签到: 23 天
     楼主| 发表于 2022-12-1 16:07:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Spectral Measurements工具包
    Spectral Measurements工具包为时域和频域信号提供频谱分析和频谱测量工具。
    Spectral Measurements工具包是LabVIEW、C和.NET的一款附加软件,提供了用于频谱分析和频谱测量的功能和工具。借助该工具包,您可以对时域数据执行连续(实时)或块(无损)缩放FFT处理,以计算所需的结果,例如原始FFT、幅度谱、功率谱、互谱、频率响应和频谱图。使用Spectral Measurements工具包,您可以对处理后的数据,比如频带功率、相邻信道功率(ACP)、占用带宽(OBW)、峰值搜索等执行频谱测量。Spectral Measurements工具包还提供了高级处理参数,包括分辨率带宽(RBW)、加窗、滤波、单位转换和各种频谱均值法。
    发布日期:2011/06/02
    包含的版本:2.6.1
    受支持的操作系统
    Windows 7 (32-bit)
    Windows 7 (64-bit)
    Windows Vista (32-bit)
    Windows Vista (64-bit)
    Windows XP
    Windows Server 2003 (32-bit)
    Windows Server 2008 (32-bit)
    文件大小: 447690752 字节 (426.95 MB)
    修改日期: 2019-05-14 22:48
    MD5: 3dcd18312318446853c8abdac71f8906(官方正确)
    SHA1: ca775d8ef011359d96b56831e5c09a83d9ffc5e5
    SHA256: 20be305c6555f901c52d042b8a74ea4a0675258b506d67ba05a7a47eec720b59
    CRC32: f2fba996
    请注册登录视觉论坛账号,购买附件查看下载地址
    SMT2.6.1.txt (499 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Spectral Measurements Toolkit Readme
    Version 2.6
    Thank you for using the NI Spectral Measurements Toolkit (SMT). This file contains important information about this release and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Licensing
    • Supported Drivers
    • Examples
    • Documentation
    • Uninstalling/Modifying the Spectral Measurements Toolkit
    • Known Issues
    • Bug Fixes
    New FeaturesNI Spectral Measurements Toolkit 2.6 includes the following new features:
    • Support for Windows Vista (64-bit) and Windows 7 (64-bit) operating systems.
    • Support for generating and applying pulse shaping filter on user-defined regions of a given spectrum through the addition of a new palette-level VI—SMT Filter Spectrum VI.
    • Addition of the SMT Spectrum Peak Search (Advanced) VI.
    • Addition of the SmtFilterSpectrum and SmtSpectrumPeakSearchMaxNPeaks functions.
    NI Spectral Measurements Toolkit 2.5 includes the following new feature:
    Japanese localization for LabVIEW application programming interface (API) and documentation.
    NI Spectral Measurements Toolkit 2.4 includes the following new features:
    • Support for LabVIEW Real-Time Module 8.5 or later (on PXI systems).
    • Support for NI PXIe-5663 RF vector signal analyzer.
    • Addition of the SMT Adjacent Channel Power (Advanced) VI and the SmtAdjacentChannelPowerAdvanced function.
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    This section lists the minimum system requirements and the recommended system for using this toolkit.
    Minimum System
    Before installing the Spectral Measurements Toolkit software, verify that your system meets the following requirements:
    • Windows 7 (32-bit)/Windows 7 (64-bit)/Windows Vista (32-bit)/Windows Vista (64-bit)/Windows XP/Windows Server 2003 (32-bit)/Windows Server 2008 (32-bit), with all available critical updates and service packs
    • 3 GB of free hard drive space
    • 256 MB of RAM
    • NI LabVIEW 8.5.1, 8.6.1, 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 (32-bit), or 2010 (64-bit), Full Development System or Professional Development System
    • LabWindows™/CVI™ 8.1, 8.5, 8.5.1, 9.0, 2009, or 2010
    Recommended System
    For optimal performance, NI recommends that your system meets the following requirements:
    • 4 GB of free hard drive space
    • 1 GB of RAM
    Note:  The SMT Run-Time Engine must be installed on systems running applications built using the Spectral Measurements Toolkit and LabWindows/CVI. The SMT Run-Time installer is available on the NI Spectral Measurements Toolkit CD in the NISMTCVIRTE folder (setup.exe).
    Licensing
    For details on activating the NI Spectral Measurements Toolkit, refer to the Activating Your Software section in the LabVIEW help file. The evaluation mode for the NI Spectral Measurements Toolkit is 30 days from the date of installation. You can access all the features of the toolkit in the evaluation mode. Refer to the software license file for further licensing requirements.
    Note:  Licensing is available only for LabVIEW.
    Supported Drivers
    Install all instrument drivers for the hardware you intend to use before installing the Spectral Measurements Toolkit. The toolkit supports the following drivers:
    • NI-RFSA 2.1 or later
    • NI-SCOPE 3.4 or later
    If you install one or more of the aforementioned drivers after installing the Spectral Measurements Toolkit 2.6, driver-specific toolkit examples and palette VIs are not present. To install these driver-specific files, you can run the "Modify" function from the Spectral Measurements Toolkit installer. To do so, follow the instructions found in the Uninstalling/Modifying the Spectral Measurements Toolkit section.
    Installed File Locations
    Verify that LabVIEW and/or CVI and any supported drivers you intend to use with the toolkit are installed on your system prior to installing the toolkit. Install the toolkit by inserting the toolkit CD into your drive and clicking setup.exe.
    Note:  When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run the installer in silent mode from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    Documents folder location, :
    • Windows XP: \All Users\Documents
    • Windows Vista/7: \Public\Documents
    FilesInstalled Location
    VIs\vi.lib\addons\Spectral Measurements Toolset
    Examples\examples\Spectral Measurements Toolset
    LabWindows/CVI
    Header Files\National Instruments\Shared\CVI\Include
    Static Libraries\National Instruments\Shared\CVI\Bin\msvc
    \National Instruments\Shared\CVI\Bin\msvc64
    .lfp/.sub Files\National Instruments\Shared\CVI\Bin
    Examples\National Instruments\CVI\samples\smt
    C
    Header Files\National Instruments\Shared\ExternalCompilerSupport\C\include
    Import Library\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc
    \National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc
    Notes On Creating Modulation Executables Using Spectral Measurements Toolkit and LabVIEW Application Builder, available on the National Instruments Web site, contains information about which VIs must be included as dynamic VIs in LabVIEW Application Builder for the executable file to run correctly.
    Examples
    LabVIEW users can use the NI Example Finder to search or browse examples. Spectral Measurements Toolkit examples are classified by keyword, so you can search for a particular device or measurements function. With LabVIEW running, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including Spectral Measurement Toolkit examples) and their descriptions.
    • Click the Browse tab to locate examples by task at Toolkits and Modules»Spectral Measurements or by directory structure at Spectral Measurements Toolset.
    • Click the Search tab to search all installed examples by keyword. For example, searching for "spectral" can be used to locate Spectral Measurements Toolkit examples.
    Note:  Links to the Spectral Measurements Toolkit examples are also available from the Start menu at All Programs»National Instruments»Spectral Measurements»LabVIEW Support and All Programs»National Instruments»Spectral Measurements»CVI Support.
    The product documentation is available at Start»All Programs»National Instruments»Spectral Measurements. Visit ni.com/manuals for the latest versions of product documentation. The documentation for the Spectral Measurements Toolkit includes the following items:
    • NI LabVIEW Spectral Measurements Toolkit Help
    • NI Spectral Measurements Toolkit Function Reference Help
    • NI Spectral Measurements Toolkit User Guide
    • NI Spectral Measurements Toolkit Readme (this document)
    • Click Change/Remove.
    • Select NI LabVIEW Spectral Measurements Toolkit 2.6 from the dialog box that appears.
      Note:  To uninstall or modify the Spectral Measurements Toolkit for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit 2.6 from the dialog box that appears.
      Note:  To uninstall or modify the Spectral Measurements Toolkit Runtime for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit Runtime 2.6 from the dialog box that appears.
    You can access the software and documentation known issues list online. Refer to the NI Spectral Measurements Toolkit 2.6 Known Issues List web page on the National Instruments Web site for an up-to-date list of known issues in NI Spectral Measurements Toolkit 2.6.
    The following issue was fixed between Spectral Measurements Toolkit 2.5.1 and Spectral Measurements Toolkit 2.6.
    34854The SMT peak search routine does not detect peaks that fall on the power spectrum boundaries.
    The following issue was fixed between Spectral Measurements Toolkit 2.5 and Spectral Measurements Toolkit 2.5.1.
    198949Japanese language LabVIEW support may get installed for non-Japanese LabVIEW.
    ©2004—2011 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, CVI, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    For patents covering the National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-10-29 12:19
