查看: 2971|回复: 0
[NI软件产品] NI OPC Servers 2016 Win32/64Eng NI OPC服务器2016
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 2022-12-1 10:38:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    OPC Servers
    OPC服务器提供单一、一致的接口,可通过OPC标准与多个设备通信。
    OPC服务器是LabVIEW的一款附加软件,可将专用工业协议转换为开放式OPC Classic和OPC统一架构(UA)协议。通过该转换,LabVIEW应用程序就可以通过LabVIEW OPC UA工具包附带的OPC UA客户端,与许多不同的可编程逻辑控制器(PLC)和第三方设备进行通信,因而用户只需在一个平台上即可对工业系统进行高性能测量和控制。
    NI OPC Servers 2016
    发布日期:2016/1/29
    包含的版本:2016完整版
    受支持的操作系统
    Windows 10 (32-bit and 64-bit)
    Windows 8 (32-bit and 64-bit)
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP Service Pack 3 or later
    Windows Server 2008 R2 (64-bit)
    Windows Server 2003 R2 (32-bit)
    文件大小: 228811328 字节 (218.21 MB)
    修改日期: 2016-03-29 00:00
    MD5: 0d6b9013b5143a7a841b8b4a0a29707b(秒传)
    SHA1: 23a2e62ed2845e5ccf6b84dbcd21c9d0ebc43676
    SHA256: 786396cf8238cb71e6d96ca4ec0076bafd879dc8cfa7338d23a80207fe7c86ea
    CRC32: c696f263
    请注册登录视觉论坛账号,购买附件查看下载地址
    OPC Server2016.txt (497 Bytes, 下载次数: 6, 售价: 10 圆)
    NI OPC Servers 2016 Readme
    January 2016
    This file contains important information about the NI OPC Servers, including system requirements, installation and activation instructions, and a list of new drivers.
    Licensing and Activation
    Drivers Usage
    New Drivers and Changes
    NI OPC Servers provides a single consistent interface to communicate with multiple devices, saving you from learning new communication protocols and spending time understanding new applications. The combination of NI OPC Servers and other NI products, such as LabVIEW, the LabVIEW Datalogging and Supervisory Control (DSC) Module, Lookout, Measurement Studio, and LabWindows™/CVI™, provides a single platform for delivering high-performance measurements and control to new and existing industrial systems.
    NI OPC Servers has both software and hardware minimum system requirements. This application supports the following operating systems:
    • Windows 10 (32-bit and 64-bit)
    • Windows XP Service Pack 3 or later
    Note  NI OPC Servers does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    NI OPC Servers has the following minimum hardware requirements:
    • 2.0 GHz processor
    • 1 GB installed RAM
    • 180 MB available disk space
    • Ethernet card
    • Super VGA (800x600) or higher resolution video card
    • CD-ROM or DVD Drive
    The following table lists the application software versions, including service packs, supported by NI OPC Servers.
    Application SoftwareVersions Supported by NI OPC Servers 2016
    LabVIEW2013, 2014, 2015
    DSC Module2013, 2014, 2015
    Lookout6.6
    Note  The DSC Module must be the same version as LabVIEW.
    NI OPC Servers connects through the OPC client in the DSC Module to enable you to develop a full-fledged Human Machine Interface (HMI) and Supervisory Control and Data Acquisition (SCADA) system with programmable logic controllers (PLCs), programmable automation controllers (PACs), and smart sensors.
    Note  By default, NI OPC Servers installs with the DSC Module for a two-hour evaluation period and with Lookout fully-licensed.
    Complete the following steps to install NI OPC Servers if you purchased NI OPC Servers separately from the DSC Module or Lookout.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before the installation. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert the NI OPC Servers installation media and follow the instructions that appear on the screen.
    • Activate NI OPC Servers using the NI License Manager.
    NI OPC Servers installed with Lookout is licensed. NI OPC Servers installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using NI OPC Servers after the evaluation period expires.
    Use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager, to activate NI products.
    Drivers Usage
    NI OPC Servers supports numerous drivers for communication to third-party devices. You can connect to one driver at a time or an unlimited number of drivers simultaneously. To learn about driver usage in NI OPC Servers and to determine the number of drivers you can simultaneously connect to, visit ni.com/info and enter the info code opcdriverusage.
    NI OPC Servers 2016 supports the following new drivers:
    • Allen-Bradley ControlLogix Unsolicited
    • Allen-Bradley Micro800 Serial
    • Allen-Bradley Micro800 Ethernet
    • Omron NJ Ethernet
    • OPC XML DA Client
    For a complete list of drivers that NI OPC Servers supports, visit ni.com/info and enter the info code opcdriverlist.
    Refer to the NI website at ni.com/opc or the NI OPC Servers Help, available by selecting Start»All Programs»National Instruments»OPC Servers 2016»OPC Servers Help, for more information about NI OPC Servers.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, click the down arrow on the bottom left of the screen.
    For more information about NI support for Windows 8.1, visit ni.com/windows8.
    NI OPC Servers Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI OPC Servers will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI OPC Servers that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    Important Information
    © 2007–2016 National Instruments. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in NI OPC Servers, refer to the NI_OPC_Servers_notice.pdf file located in the National Instruments\Shared\NI OPC Servers\V5 directory.
    375754A-01
    GMT+8, 2026-4-1 12:56
